[Solved] Smplayer no longer works
erbou
Post by erbou » Fri Jan 12, 2018 3:44 am
Hello,
I had to reinstall MX-16.1 (Nov 2017 release) and I got this error message as running Smplayer for the first time :
/home/tt/.config/smplayer/styles.ass -subfont-autoscale 0 -subfont-text-scale 20 -subcp ISO-8859-1 -subpos 100 -volume 84 -cache 2048 -ss 63 -osdlevel 0 -vf-add screenshot -noslices -channels 2 -af scaletempo -softvol -softvol-max 110 /media/Data-2/Musique/Blues/Eric Clapton-02-Before You Accuse Me-1992-UNPLUGGED.mp4
Error parsing option noquiet (option not found)
Setting commandline option --noquiet= failed.
Exiting... (Fatal error)
I uninstalled mpv and Smplayer then re-install both of them with Synaptic and ran Smplayer again : it didn't help.
1st boot: Linux ttx 4.7.0-0.bpo.1-amd64 #1 SMP MX 4.7.8-1mx16+3 (2017-02-23) x86_64 GNU/Linux
2nd boot: Windows 7 Home Edition
Processor: Intel i5-4570 - Ram: 16 Gb - NAS: Synology DS216j - DSM 6.1
penguin
Re: Smplayer no longer works
Post by penguin » Fri Jan 12, 2018 9:51 am
This message comes up when you tried to play eric*.mp4 or when you open Smplayer for the first time ?
If this happen when you tried to open Smplayer without playing nothing...means Smplayer is looking to play smth from previous history and the path is not valid , I guess.
I never have problem with mpv or even smplayer.
I made a search for you in google :-).
https://www.google.no/search?client=ope ... 2pEu6WRmk4
Try > Mx Tools and install Multimedia Codecs if you have not installed them.
erbou
Post by erbou » Fri Jan 12, 2018 2:11 pm
In the settings, I changed the Executable Mplayer from mpv to mplayer : Smplayer now reads my video but it remains mute !
erbou
[Solved] Re: Smplayer no longer works
Post by erbou » Fri Jan 12, 2018 2:33 pm
I changed the output driver to alsa and everything is fine.
Re: [Solved] Smplayer no longer works
Post by Stevo » Fri Jan 12, 2018 3:17 pm
It appears that SMPlayer no longer works with the rather old version of mpv we have in the main repository, or the default "mplayer" in Jessie, which is actually the defunct mplayer2. I'll see about bumping up the minimum dependencies for those.
dr-kart
Post by dr-kart » Sat Jan 13, 2018 6:32 am
Stevo wrote:rather old version of mpv we have in the main repository
mpv won't play youtube live streaming too.
https://github.com/mpv-player/mpv/issues/5286
Post by Stevo » Sat Jan 13, 2018 7:07 pm
The mpv 0.27 version in the test repo worked a couple days ago when I used it as the backend in SMPlayer 17.12.2 and set the streaming to use mpv + youtube-dl. The 18.1.0 update was supposed to fix this with the "Auto" setting.
dr-kart
Post by dr-kart » Sun Jan 14, 2018 5:17 am
Stevo wrote:The mpv 0.27 version in the test repo worked a couple days ago when I used it as the backend in SMPlayer 17.12.2 and set the streaming to use mpv + youtube-dl.
it's not working with live youtube streaming videos. As the link describes above.
Any other not-live streams are fine with mpv + youtube-dl option. 0.27 is included.
kb50
Post by kb50 » Sun Jan 14, 2018 9:06 pm
Same here, I installed SmTube player, and it shows several links, but nothing opens. Just get URL Not found.
Do I need SmPLayer installed as well? Guess I can just go get SmPlayer to see if that is the cure? I just now got an update on Package Manager.
Would like to see that developed more, for those like me that are just not confident in using terminal commands.
{erhaps a future suggestion to just have a notifier of newly packaged items. It's a very accurate, and useful tool. Perhaps also to automate Y when prompted, but I usually enjoy watching
it install anyhow, just so I can catch any errors.
#10
Post by Stevo » Sun Jan 14, 2018 10:34 pm
Live streaming seems to be a known issue. I will build smtube-18.1.0, but it seems we would need mpv-0.28, too.
https://forum.smplayer.info/viewtopic.p ... =30#p17518
Mpv 0.28 is not in Debian yet, but I tried building it against ffmpeg 3.4.1, which should have been good since they said 3.4 is the minimum. It failed when it wanted even newer, unreleased libraries such as libavcodec58. :confused:
