-- Change in MX sources
-- antiX-17 release info here
Volume scrolling set
balarm
#1 Post by balarm » Tue Jan 09, 2018 4:13 pm
Hi everybody,you can set the volume by scrolling on the it's icon-panel from 0 > 100% .
To raise it more (153%) it's necessary to Open Mixer and set it manually. Isn't it possible doing it by scrolling???
Thanks for any help.
mx1 Kernel: 4.15.0-1-amd64 x86_64 bits: 64 Desktop: Xfce 4.12.3
Distro: MX-17.1_x64 Horizon December 15, 2017
Machine: Device: laptop System: LENOVO product: 1951A47 v: ThinkPad T60
Re: Volume scrolling set
#2 Post by Jerry3904 » Tue Jan 09, 2018 4:23 pm
If you set the slider all the way to the right (~150%) on the Output Devices tab of the mixer, does it work then?
balarm
#3 Post by balarm » Tue Jan 09, 2018 4:37 pm
Yes, it woks well.
balarm
#4 Post by balarm » Wed Jan 10, 2018 2:50 pm
Hi, no solution to raise the volume more than 100% value by scrolling the mouse?????
#5 Post by dolphin_oracle » Wed Jan 10, 2018 2:55 pm
I think you can use the pulseaudio plugin for the xfce-panel to do that. Not at a Xfce machine at the moment to check.
lenovo ThinkPad T530 - MX-17
balarm
#6 Post by balarm » Wed Jan 10, 2018 3:38 pm
The plugin you mention is installed and works fine but if i want to increase it I have to do it manually by OpenMixer>Output Device slide to 153% every time.
No problem if i have to do (increase) it manually every time.
#7 Post by richb » Wed Jan 10, 2018 4:21 pm
balarm wrote:The plugin you mention is installed and works fine but if i want to increase it I have to do it manually by OpenMixer>Output Device slide to 153% every time.
THat is the way it works on my system as well. Mouse scroll will take it to 100%. To get beyond that you have to open the mixer.
Rich
SSD Production: MX 17.1
#8 Post by dolphin_oracle » Wed Jan 10, 2018 4:48 pm
there is another volume control i used in the mx15 days. it would let you ramp up beyond 100% with just the mouse. I'll check my stuff and see if I can find the name of it. it was in the debian jessie repo.
kmathern
#9 Post by kmathern » Wed Jan 10, 2018 5:11 pm
dolphin_oracle wrote:there is another volume control i used in the mx15 days. it would let you ramp up beyond 100% with just the mouse. I'll check my stuff and see if I can find the name of it. it was in the debian jessie repo.
I use Pasystray for volume control, it's also available in the Debian Stretch repo
It'll go well past 100%, I've had it up to greater than 1000% before I got tired of spinning the mousewheel.
#10 Post by dolphin_oracle » Wed Jan 10, 2018 5:22 pm
that's the one I used! thanks kmathern!
