  • Mepis support still here
  • MX-16.1 release info here
  • antiX-17 release info here
    • Read Forum Rules
Can't Config Wine
towwire
Can't Config Wine
#1 Postby towwire » Sun May 14, 2017 12:32 pm
I installed Wine-Staging and Wine-Staging-amd64 from test and I don't have the other menu to config wine. I show the wine files in /opt/wine-staging but no files in my home. How do I do the config of wine?
Re: Can't Config Wine
#2 Postby timkb4cq » Sun May 14, 2017 12:39 pm
Open a terminal & type:
winecfg
That will create the hidden ~/.wine folder.
towwire
#3 Postby towwire » Sun May 14, 2017 12:43 pm
timkb4cq wrote:Open a terminal & type:
winecfg
I tried that.
towwire@mx16Laptop:~
$ winecfg
bash: winecfg: command not found
I even trid it as root, same results
#4 Postby timkb4cq » Sun May 14, 2017 12:51 pm
You can either run /opt/wine-staging/bin/winecfg *or* install winehq-staging whichs creates the symlinks to /usr/bin.
The reason it's not a dependency is that some people want both the stable wine & wine-staging on the same machine. I use winhq-staging - it's easier.
towwire
#5 Postby towwire » Sun May 14, 2017 1:06 pm
I did this and the winecfg came up but when I tried to test the sound it disappeared. Nothing created in my home and I could not fine what the output said it created.
root@mx16Laptop:/opt/wine-staging/bin# winecfg
root@mx16Laptop:/opt/wine-staging/bin# bash winecfg
wine: created the configuration directory '/root/.wine'
fixme:winediag:start_process Wine Staging 2.7 is a testing version containing experimental patches.
fixme:winediag:start_process Please mention your exact version when filing bug reports on winehq.org.
err:ole:marshal_object couldn't get IPSFactory buffer for interface {00000131-0000-0000-c000-000000000046}
err:ole:marshal_object couldn't get IPSFactory buffer for interface {6d5140c1-7436-11ce-8034-00aa006009fa}
err:ole:StdMarshalImpl_MarshalInterface Failed to create ifstub, hres=0x80004002
err:ole:CoMarshalInterface Failed to marshal the interface {6d5140c1-7436-11ce-8034-00aa006009fa}, 80004002
err:ole:get_local_server_stream Failed: 80004002
fixme:ntdll:NtLockFile I/O completion on lock not implemented yet
err:mscoree:LoadLibraryShim error reading registry key for installroot
err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
fixme:dwmapi:DwmIsCompositionEnabled 0x6dbd1518
fixme:iphlpapi:NotifyIpInterfaceChange (family 0, callback 0x69ebd3de, context 0x9c67e0, init_notify 0, handle 0x12ae1c0): stub
fixme:dwmapi:DwmIsCompositionEnabled 0x6d5d3018
fixme:iphlpapi:NotifyIpInterfaceChange (family 0, callback 0x6a0cb608, context 0x938918, init_notify 0, handle 0x116e794): stub
wine: configuration in '/root/.wine' has been updated.
#6 Postby timkb4cq » Sun May 14, 2017 1:37 pm
Wine is not designed to be run as root. Try again as a regular user.
BTW, if you are in the /opt/wine-staging/bin directory you would normally run any executable there by prepending ./ As in ./winecfg
But normally you would run the commands from whatever folder you had the windows program in, like so:
/opt/wine-staging/bin/wine setup.exe
Who is online
Users browsing this forum: Bing [Bot] and 7 guests
