GPS not Connecting
towwire
GPS not Connecting
#1 Post by towwire »
I cannot get gpsd to show a gps connection that opencpn can see. I installed gpsd and gpsd-clients. The last time I did this with an older version of opencpn and MX it worked find. I extracted troubleshooting from /usr/share/doc/gpsd/ and have tried some of the commands, but nothing works. Here is some info first.
$ inxi -F
System:    Host: mx16-laptop Kernel: 4.9.0-1.1-liquorix-amd64 x86_64 (64 bit) Desktop: Xfce 4.12.2
           Distro: MX-16_x64 Metamorphosis 12 December 2016
Machine:   Device: laptop System: GIGABYTE product: P15FV5
           Mobo: GIGABYTE model: P15FV5 UEFI: American Megatrends v: 1.05.09RGI1 date: 12/03/2015
Battery    BAT0: charge: 42.2 Wh 100.0% condition: 42.2/44.0 Wh (96%)
CPU:       Quad core Intel Core i7-6700HQ (-HT-MCP-) cache: 6144 KB
           clock speeds: max: 2601 MHz 1: 1400 MHz 2: 2000 MHz 3: 800 MHz 4: 800 MHz 5: 800 MHz
           6: 800 MHz 7: 900 MHz 8: 900 MHz
Graphics:  Card-1: Intel Device 191b
           Card-2: NVIDIA Device 139a
           Display Server: X.Org 1.16.4 drivers: modesetting,nouveau,intel (unloaded: fbdev,vesa)
           Resolution: 1920x1080@60.02hz
           GLX Renderer: Mesa DRI Intel HD Graphics 530 (Skylake GT2) GLX Version: 3.0 Mesa 12.0.3
Audio:     Card Intel Device a170 driver: snd_hda_intel Sound: ALSA v: k4.9.0-1.1-liquorix-amd64
Network:   Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169
           IF: eth0 state: down mac: 80:fa:5b:30:92:9e
           Card-2: Realtek RTL8723BE PCIe Wireless Network Adapter driver: rtl8723be
           IF: wlan0 state: up mac: 30:52:cb:e2:78:c8
Drives:    HDD Total Size: 1128.2GB (3.2% used)
           ID-1: /dev/sdb model: WDC_WD10JPVX size: 1000.2GB
           ID-2: /dev/sda model: TS128GMTS800 size: 128.0GB
Partition: ID-1: / size: 15G used: 5.9G (43%) fs: ext4 dev: /dev/sda2
           ID-2: /home size: 25G used: 16G (66%) fs: ext4 dev: /dev/sdb1
Sensors:   System Temperatures: cpu: 40.0C mobo: N/A gpu: N/A
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 264 Uptime: 44 min Memory: 621.1/15937.0MB Client: Shell (bash) inxi: 2.3.8
Files installed with Synaptic.
2017-05-12  11:46:05  install  python-gps                                amd64  <none>                          3.11-3
2017-05-12  11:46:05  install  gpsd-clients                              amd64  <none>                          3.11-3
2017-05-12  10:48:28  install  libgps21                                  amd64  <none>                          3.11-3
2017-05-12  10:48:28  install  gpsd                                      amd64  <none>                          3.11-3
I'm using a Startech cable, USB to 2 serial connections. this cable work before and when I type this into a Terminal
stty -F /dev/ttyUSB1 ispeed 4800 && cat </dev/ttyUSB1
I have output from the gps and it keeps going till I close the terminal. If I try to start gpsd -D 5 -N -n /dev/ttyUSB1 I get this:
$ gpsd -D 5 -N -n /dev/ttyUSB1
gpsd:INFO: launching (Version 3.11)
gpsd:IO: opening IPv4 socket
gpsd:ERROR: can't bind to IPv4 port gpsd, Address already in use
gpsd:ERROR: maybe gpsd is already running!
gpsd:IO: opening IPv6 socket
gpsd:ERROR: can't bind to IPv6 port gpsd, Address already in use
gpsd:INFO: command sockets creation failed, netlib errors -1, -1
They talk about device permissions but I don't know to set them. The text file is 7.5 KB. Is there anyay to pass it on to read and help me?
Re: GPS not Connecting
#2 Post by Jerry3904 »
So is gpsd already running?
towwire
#3 Post by towwire »
Jerry3904 wrote:So is gpsd already running?
I don't know, how do you find out?
#4 Post by Jerry3904 »
I use Task Manager
towwire
#5 Post by towwire »
Shows it running.
towwire
#6 Post by towwire »
I managed to get a NMEA debug window in opencpn to shows it is receiving from the gps, but it will not move the boat to the position where the gps is located. I know that you can place the boat any where on a chart and start the gps and the boat should move on the chart to the position of the gps. It will not do it
If anyone has it working right please let me know.
Gordon Cooper
#7 Post by Gordon Cooper »
Sounds as if you have the anchor down?
GuiGuy
#8 Post by GuiGuy »
towwire wrote:I managed to get a NMEA debug window in opencpn to shows it is receiving from the gps, but it will not move the boat to the position where the gps is located. I know that you can place the boat any where on a chart and start the gps and the boat should move on the chart to the position of the gps. It will not do it
OK, this is what I get in my house with the GPS dongle hanging out of my upstairs window.
But xgps does not see my dongle.
The above results are with a "U-blox7 GPS/GLONASS" dongle on MX16.
Tried a "G-STAR IV BU-353S4" dongle: openCPN does not see this one; xgps results same as the U-blox7.
GuiGuy
#9 Post by GuiGuy »
Now on MX15.
With the U-blox7 dongle:
xgps still does not see this dongle.
But on this (MX15) OS xgps does work with the BU-353S4 dongle
Furthermore foxtrotGPS works fine with BU-354S4 but not with U-blox7.
towwire
#10 Post by towwire »
Funny, I installed opencpn on my desktop machine and just plug-in the usb, It put a symbol on the back ground about where I live, Lat & long seem to be correct, Did not install gpsd.
