MX 16.1 Beta 1 now available for testing Information here
NewsCurrent releases
  • MX-16 release info here
  • antiX-16 release info here
  • Read Forum Rules
Firefox Sound Notifications
bonbonboi
#1 Postby bonbonboi » Sun May 07, 2017 6:36 am
Hello, I don't hear any sound notifications when I get messages or notifications on Facebook, on Windows (at work) I get those sound notifications, but at home (MX) no sound notifications, I have no clue where the issue is :frown:
Re: Firefox Sound Notifications
#2 Postby Jerry3904 » Sun May 07, 2017 6:45 am
Not enabled by default: use MX System Sounds to enable and select. Check Help file if you have questions.
Production: 4.7.0-0.bpo.1-amd64, MX-15 RC1, AMD FX-4130 Quad-Core, GeForce GT 630/PCIe/SSE2, 8 GB, Kingston SSD 120 GB and WesternDigital 1TB
Testing: AAO 722: 3.16-0-4-686-pae. MX-15, AMD C-60 APU, 4 GB
bonbonboi
#3 Postby bonbonboi » Sun May 07, 2017 2:07 pm
Jerry3904 wrote:Not enabled by default: use MX System Sounds to enable and select. Check Help file if you have questions.
#4 Postby Jerry3904 » Sun May 07, 2017 2:26 pm
MX System Sounds: type it in the menu or go through MX Tools.
Note 1: what you get with Windows has nothing to do with what you get with MX Linux, they are completely different systems.
Note 2: not all sounds may be available for the sound set you use, you will have to explore and play around a bit.
bonbonboi
#5 Postby bonbonboi » Sun May 07, 2017 4:51 pm
Jerry3904 wrote:MX System Sounds: type it in the menu or go through MX Tools.
I'm not comparing between Windows and MX Linux, It's just a personal inquiry, hopefully someone got an idea about it before I mess with stuff. It's mainly related to Firefox as I think, any way I'm going to reset FF's pref.js and test again.
About MX Tools, I've tried to install packages through it, and it failed. I'm going to install pkgs with command line, as I always do before MX Tools. Even PepperFlash gives a failed message, any way what I understood about MX Tools, it is an Assistant, but things could be done else where.
#6 Postby Jerry3904 » Sun May 07, 2017 4:53 pm
whatever makes you happy
#7 Postby Stevo » Sun May 07, 2017 5:15 pm
Well, we are certainly interested in getting to the root of your problems with MX-Tools, especially if we can reproduce them. Can you start a thread for each issue? You don't have to have them all at once.
Who is online
Users browsing this forum: Toastrack and 1 guest
