-- Change in MX sources
-- antiX-17 release info here
[SOLVED] MX-16 issue: "Clawsker" has no starter icon
MX-16_fan
#1 Post by MX-16_fan » Mon Apr 24, 2017 3:48 pm
Clawsker (http://www.claws-mail.org/clawsker.php - package name: "clawsker") is an application that allows you to change Claws Mail's hidden preferences. While it is a GUI app, it lacks a starter button in MX-16 after installation. Greetings, Joe
Re: MX-16 issue: "Clawsker" has no starter icon
#2 Post by Stevo » Mon Apr 24, 2017 5:14 pm
I'd say it's a Debian problem instead of just an MX-16 issue--it doesn't install any desktop file or icon, using instead the old, deprecated menu system. One workaround that the user can use is to create a desktop file with the menu editor.
The version in Stretch does incorporate the the fixes, including a desktop file; let's see if it can be backported to our test repo.
#3 Post by Stevo » Mon Apr 24, 2017 5:27 pm
OK, the fix came from clawsker's source, not from anything that the Debian maintainer did. The 1.0.1 version in upstream Debian is already been surpassed by Clawsker 1.1.0, so I packaged that version: https://drive.google.com/open?id=0BxE7w ... mdEX1NjbXc
MX-16_fan
#4 Post by MX-16_fan » Wed Apr 26, 2017 8:07 am
@Stevo:
Stevo wrote:OK, the fix came from clawsker's source, not from anything that the Debian maintainer did. The 1.0.1 version in upstream Debian is already been surpassed by Clawsker 1.1.0, so I packaged that version: https://drive.google.com/open?id=0BxE7w ... mdEX1NjbXc
Very cool, thank you.
* Are you putting this into the Test Repo?
* Can I mark this thread as "solved"?
Greetings, Joe
#5 Post by Stevo » Wed Apr 26, 2017 2:41 pm
Yes, 1.1.0 is in the testing repo, and it has a working menu entry and icon on my system. Let us know how it's working for you!
MX-16_fan
#6 Post by MX-16_fan » Wed Apr 26, 2017 3:23 pm
@Stevo:
Stevo wrote:Yes, 1.1.0 is in the testing repo, and it has a working menu entry and icon on my system. Let us know how it's working for you!
Thanks a lot. I'll test it for some time and then report on it. Greetings, Joe
MX-16_fan
#7 Post by MX-16_fan » Fri May 19, 2017 8:48 am
@all:
MX-16_fan wrote:@Stevo:
Seems to work fine. I'll mark this "SOLVED". Thanks ever so much to Stevo for packaging the new version for the MX Test Repo – you're really great!
