-- Change in MX sources
-- antiX-17 release info here
[SOLVED] Can't perform dist-upgrade because packages cannot be authenticated
MX-16_fan
#1 Post by MX-16_fan » Tue Feb 14, 2017 12:16 pm
- UPDATE: In a prior version of this posting, I wrote that I had typed "sudo apt-get install update" etc., which I did not to. No "install" command/option in play here. I now corrected that rightaway in this post. Please excuse. -
Hi all,
on my freshly installed MX-16 64-Bit (January snapshot), I rightaway did a
sudo apt-get update
and a
sudo apt-get upgrade
Both of these worked out fine.
However, when I tried the
sudo apt-get dist-upgrade
it told me that the following packages cannot be authenticated:
 libftgl2 libqt4-sql-sqlite libqxt-core0 libqxt-gui0 libprojectm2
Why is that, and what can I do about that?
Thanks in advance for any help, Joe
gimcrack
Re: Can't perform dist-upgrade because packages cannot be authenticated
#2 Post by gimcrack » Tue Feb 14, 2017 12:26 pm
Try out these commands
sudo apt-key update
sudo apt-get update
Even run these.
sudo dpkg --configure -a
sudo apt-get install -f
Now does sudo apt-get dist-upgrade works?
kmathern
#4 Post by kmathern » Tue Feb 14, 2017 12:34 pm
MX-16_fan wrote:Hi all,
and a
sudo apt-get install upgrade
sudo apt-get install dist-upgrade
Leave out the word "install" when running those apt-get commands, you only need to include it when actually installing individual package(s) not when updating, upgrading, dist-upgrading.
sudo apt-get update
MX-16_fan
#5 Post by MX-16_fan » Tue Feb 14, 2017 12:59 pm
@kmathern:
kmathern wrote: Leave out the word "install" when running those apt-get commands, you only need to include it when actually installing individual package(s) not when updating, upgrading, dist-upgrading.
Sorry, I got confused here, "apt-get update" etc. was what I actually did, without the "install". I will try to correct my original posting as far as that's concerned.
Greetings, Joe
kmathern
#6 Post by kmathern » Tue Feb 14, 2017 1:10 pm
MX-16_fan wrote:@kmathern:
Greetings, Joe
Okay, could you post the actual error message(s) about being unable to authenticate those packages?
Fwiw I just had those same packages installed earlier today during the initial dist-upgrade on a relatively new MX-16 install and there weren't errors/warnings about them.
MX-16_fan
#7 Post by MX-16_fan » Tue Feb 14, 2017 1:18 pm
gimcrack wrote: Try out these commands
sudo apt-key update
Thanks, this leads me to:
gpg: Total number processed: 7, gpg: unchanged: 7
gimcrack wrote: sudo apt-get update
Doing this afterwards gets him to contact the repos and to finish telling me
Reading package lists... Done
gimcrack wrote: Even run these.
Processed in a second or so without any further comment from the system.
gimcrack wrote: sudo apt-get install -f
Output:
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
gimcrack wrote: Now does sudo apt-get install dist-upgrade works?
No, this only gives me
E: Unable to locate package dist-upgrade
Greetings, Joe
MX-16_fan
#8 Post by MX-16_fan » Tue Feb 14, 2017 1:27 pm
@gimcrack:
Thanks for the link to the instructions on how to fix this error. I am just walking through that. The first chapter there is called "Check Repositories". Well, on
sudo apt-get update
I noticed that by default MX-16 tells me stuff like
Ign http://nl.mxrepo.com mx15/main Translation-en
Might is be related to this problem – why is MX-15 stuff in here in anyway?
Greetings, Joe
topcat
#9 Post by topcat » Tue Feb 14, 2017 1:33 pm
CODE: SELECT ALL
Once again should be
"sudo apt-get dist-upgrade"
not
"sudo apt-get install dist-upgrade"
Zotac ZBOX-ID91-U (desktop system)
SanDisk Extreme Pro 240GB SATA III SSD
G.SKILL 8GB DDR3 1600 (PC3 12800)
ZOTAC ZBOX nano ID62-U (media streamer)
Silicon Power Slim S60 120GB SATA III SSD
G.SKILL Ripjaws 4GB DDR3L 1600 (PC3L 12800)
kmathern
#10 Post by kmathern » Tue Feb 14, 2017 1:38 pm
MX-16_fan wrote:... Well, on
sudo apt-get update
I wouldn't worry about the "Ign http://..." lines you see in the `apt-get update` terminal output, for the most part they're harmless.
MX-16 uses both the mx15 amd mx16 MX repos
