WLAN (WIFI) works under MX-16.1, MX-17 does not
waldmattis
Post by waldmattis » Sun Jun 10, 2018 4:55 am
Good morning
I have problems with the WLAN.
When I use MX-16.1, both my laptop's built-in interface and USB wireless devices are displayed.
I can access the Internet via WLAN without any problems.
But if I use MX-17, I get the message that the WLAN hardware holder of my laptop is switched off.
A WLAN connection is not possible.
How can it be that MX-16.1 ignores the switch position, but MX-17 does not?
Is there a possibility that MX-17 also ignores the switch?
Any help is welcome.
Thank you very much.
regards
Charles
Ps
Windows 7 also denies WLAN with the note that the hardware switch is switched off.
Re: WLAN (WIFI) works under MX-16.1, MX-17 does not
Post by Jerry3904 » Sun Jun 10, 2018 6:06 am
Check if the button under "Wifi status" in MX Network Assistant works for you.
waldmattis
Post by waldmattis » Sun Jun 10, 2018 6:34 am
@Jerry3904
The Status message is
The hardware switch is off
There is nothing I could click to switch
Post by dolphin_oracle » Sun Jun 10, 2018 9:26 am
is there a bios switch for the wife? eeepc's had them at one time, and when you switched off the wireless, you actually changed a bios setting. even with the keyboard combination to turn off/on wifi, especially in windows.
that is something to look for, especially if windows 7 is reporting the hardware switch off as well as MX17. If you've tried mx16 (after the switch is reported off) and it works, I'm honestly at a loss to explain that.
lenovo ThinkPad T530 - MX-18
sleekmason
Post by sleekmason » Sun Jun 10, 2018 9:54 am
I know for myself, if I don't enable my wifi in the live environment, It doesn't show up whether I create it or not. New install?
Post by fehlix » Sun Jun 10, 2018 10:14 am
Would you let us know a bit about you hardware you are using avoiding us poking in the fog.
In additon it's always good practice to post output from "Quick System Info" for system and hardware related questions (or use inxi -Fx from command line).
Thanks
waldmattis
Post by waldmattis » Sun Jun 10, 2018 12:30 pm
Yes, you are right.
On the original keyboard is (better: was) a key combination to Switch WLAN on or off.
Regrettably this keyboard is broken and now I use a wireless keyboard without this function.
The BIOS shows two choice for WLAN:
- Start with last status
- Switch WLAN off
So there is no option in BIOS to activate WLAN.
What surprises me is that MX-16.1 does not have to take care of the alleged hardware switch.
But MX-17 takes the switch into account.
It is an 9-year-old Medion laptop with Intel board.
No secure boot or the like.
Regards
Karl
Post by fehlix » Sun Jun 10, 2018 12:49 pm
Please do show us the output of this command from the command line:
inxi -FNzx
Put the output within [code][/code] tags
by pressing the code-tag icon above the editor-window </>
and paste between the code tags [code]paste the output here[/code] .
Thanks
Post by dolphin_oracle » Sun Jun 10, 2018 1:15 pm
the only thing different that mx16 does that mx17 doens't do is restart the network-manager service after log in.
so I guess you could try that.
sudo service network-manager restart
but IMO its a long shot.
waldmattis
#10
Post by waldmattis » Sun Jun 10, 2018 1:18 pm
karl@mx1:~
$ inxi -FNzx
System: Host: mx1 Kernel: 4.7.0-0.bpo.1-amd64 x86_64 bits: 64 compiler: gcc v: 4.9.2
Desktop: Xfce 4.12.2 tk: Gtk 2.24.25 Distro: MX-16.1_x64 Metamorphosis 8 June 2017
Machine: Type: Laptop System: MEDION product: P6612 v: 20 serial: <filter>
Mobo: MEDION model: P6612 serial: <filter> BIOS: Phoenix v: 1.02 date: 09/11/2008
Battery: ID-1: BAT0 charge: 56.0 Wh condition: 56.0/65.1 Wh (86%) model: SMP-BAK-22 M08B1
status: Full
CPU: Topology: Dual Core model: Intel Core2 Duo T5800 bits: 64 type: MCP arch: Conroe
rev: 13 L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 ssse3 bogomips: 7981
Speed: 800 MHz min/max: 800/2000 MHz Core speeds (MHz): 1: 800 2: 800
Graphics: Card-1: NVIDIA G96M [GeForce 9600M GS] driver: nvidia v: 340.102 bus ID: 01:00.0
Display: server: X.Org 1.16.4 driver: nvidia resolution: 1366x768~60Hz, 1360x768~60Hz
OpenGL: renderer: GeForce 9600M GS/PCIe/SSE2 v: 3.3.0 NVIDIA 340.102
Audio: Card-1: Intel 82801I HD Audio driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k4.7.0-0.bpo.1-amd64
Network: Card-1: Intel WiFi Link 5100 driver: iwlwifi v: kernel bus ID: 02:00.0
Card-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
v: 2.3LK-NAPI port: 3000 bus ID: 03:00.0
Card-3: Realtek RTL8187 Wireless Adapter type: USB driver: rtl8187 bus ID: 6:4
IF: wlan1 state: down mac: <filter>
Drives: HDD Total Size: 232.89 GiB used: 16.07 GiB (6.9%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
Partition: ID-1: / size: 39.25 GiB used: 16.07 GiB (40.9%) fs: ext4 dev: /dev/sda8
ID-2: swap-1 size: 4.10 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda6
Sensors: System Temperatures: cpu: 57.0 C mobo: 57.0 C gpu: nvidia temp: 67 C
Info: Processes: 181 Uptime: 8m Memory: 3.86 GiB used: 824.3 MiB (20.9%) Init: SysVinit
runlevel: 5 Compilers: gcc: 4.9.2 Shell: bash v: 4.3.30 inxi: 3.0.10
karl@mx1:~
$ inxi -FNzx
