[Thnxs for Suggestion]Please suggest which ram should i use
vamsi
Post by vamsi » Sat Jun 09, 2018 2:30 am
My system specs are:-
System:    Host: cherubim Kernel: 4.15.14-antix.1-686-smp-pae i686 bits: 32 Desktop: Xfce 4.12.3
           Distro: MX-17.1_386 Horizon March 12, 2017
Machine:   Type: Desktop Mobo: MICRO-STAR model: MS-7507 v: 1.0 serial: <root required>
           BIOS: American Megatrends v: 3.1 date: 03/01/2008
CPU:       Topology: Dual Core model: Intel Core2 Duo E4500 bits: 64 type: MCP
           L2 cache: 2048 KiB
           Speed: 2200 MHz min/max: N/A Core speeds (MHz): 1: 2200 2: 2200
Graphics:  Card-1: Intel 82945G/GZ Integrated Graphics driver: i915 v: kernel
           Display: x11 server: X.Org 1.19.2 driver: intel unloaded: fbdev,modesetting,vesa
           resolution: 1280x1024~75Hz
           OpenGL: renderer: Mesa DRI Intel 945G x86/MMX/SSE2 v: 2.1 Mesa 13.0.6
Audio:     Card-1: Intel NM10/ICH7 Family High Definition Audio driver: snd_hda_intel
           Sound Server: ALSA v: k4.15.14-antix.1-686-smp-pae
Network:   Card-1: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet driver: r8169
           IF: eth0 state: up speed: 100 Mbps duplex: full mac: 00:1d:92:a2:a1:ee
Drives:    HDD Total Size: 298.10 GiB used: 105.95 GiB (35.5%)
           ID-1: /dev/sda vendor: Western Digital model: WD1600AABS-00PRA0 size: 149.05 GiB
           ID-2: /dev/sdb vendor: Western Digital model: WD1600AAJS-08B4A0 size: 149.05 GiB
Partition: ID-1: / size: 39.12 GiB used: 20.99 GiB (53.7%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 1.91 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda1
           ID-3: swap-2 size: 250.9 MiB used: 0 KiB (0.0%) fs: swap dev: /dev/zram1
Sensors:   System Temperatures: cpu: 70.0 C mobo: N/A
Info:      Processes: 180 Uptime: 15m Memory: 1.96 GiB used: 695.0 MiB (34.6%) Shell: init
           inxi: 3.0.10
I am now using 2gb ram i.e,(1Gb+1GB) now i want to replace it with (1GB+2GB) and this is link to the website of my motherboard https://www.msi.com/Motherboard/945GCM7F.html i couldn't come to conclusion what ram should i use .So, anybody can help me with this?
Thanks..
chrispop99
Re: Please suggest which ram should i use
Post by chrispop99 » Sat Jun 09, 2018 2:42 am
That motherboard supports dual channel memory; performance would be compromised unless you use two identical sticks.
With the experience of two decades of building PC's for myself and others, I only use what Crucial suggest. Go to the Crucial website of the most appropriate country for you and use their list of devices to select the proper memory for your motherboard. Crucial have a no-quibble money back guarantee on compatibility.
It might not be the cheapest solution, but it's the most trouble free. RAM with minor faults is the worst sort of hardware issue to deal with!
Test machines:
antechdesigns
Post by antechdesigns » Sat Jun 09, 2018 2:54 am
Ideally you want matched pairs of ram, so i would suggest getting 2x 2GB= 4GB
4GB is the maximum that board will take
You need:
Unbuffered DIMM 1.8 Volt DDR2 400/533/667
Try to find:
2x2GB DDR2 that runs at 1.8v @ a speed of 667 This will give you the Max upgrade performance, for that board as far as the ram is concerned
You could sell the other 2 ram sticks
Hope this helps
vamsi
Post by vamsi » Sat Jun 09, 2018 3:22 am
At present i am using this ram
I want to buy a 2g Ram so that it supports with this same ram ofcourse i can buy 2gb ram 2 sticks but this 1 gb ram will be wasted so any suggestions
thanks..
vamsi
Post by vamsi » Sat Jun 09, 2018 4:12 am
i searched and found in online
https://www.amazon.in/Transcend-GB-DDR2 ... B001005O14
Does it will match with my ram
Thanks..
GuiGuy
Post by GuiGuy » Sat Jun 09, 2018 5:30 am
Not recommended.
Best to get a matched pair of 2g sticks.
If you must keep your existing stick, get another 1g stick to match it.
Post by fehlix » Sat Jun 09, 2018 8:08 am
Just get two new idententical 2GB "DDR2 PC2-4200 533MHz 240-pin DIMM" for your "MSI (Micro-Star) Motherboard MS-7507". You shall get it in any decent memory online shop.
GuiGuy
Post by GuiGuy » Sat Jun 09, 2018 11:19 am
If you don't like Crucial price ...
https://www.ebay.com/itm/New-4GB-2-x-2G ... J#shpCntId
vamsi
Post by vamsi » Sat Jun 09, 2018 3:16 pm
Yes for crucial ram's i have to pay international fare charge as i am living in other country lol it is really hard to trust ebay i have already booked one 2 gb ram from amazon will see how it will work if it don't i will return it to amazon :p :p :p
sacules
#10
Post by sacules » Sat Jun 09, 2018 3:41 pm
I suggest looking in your country for Kingston ones, they're very reliable and you'd probably find them for cheap.
