Broadcomm hassles :
kato
Broadcomm hassles :
Post by kato » Fri Jun 08, 2018 11:41 pm
I puechased a Dell 6400 Inspiron with a Broadcomm wifi card. I installed MX17 -32 bit.according the MX tool Drivers ,it says that it has a PRO wireless 3945ABG[GOLAN]
Netgear connection[8086:4222](REV02) 03:00.0 Broadcom Corporation BCM4401-B0100 BASE-TX[14e4:1700](rev02).
Now my query is ,would it be worthwhile to use a USB wi-fi Dongle or change the wi-fi card for a more modern ones or try to install the driver without any internet access ,either Ethernet or wifi.
Thanks,
kato
chrispop99
Re: Broadcomm hassles :
Post by chrispop99 » Sat Jun 09, 2018 2:49 am
Hi, and welcome to the forum.
Broadcom chips are the work of the devil! MX Linux can usually be made to work with them however.
As a first step, read the relevant sections of the manual, and try what is suggested there. (Press Alt-F1 to access the manual, then press Ctrl-f to open the search function. Type Broadcom, then you can use the up and down arrows in the search field to go through the information there.)
If nothing there helps, post back here.
Test machines:
Post by Stevo » Sat Jun 09, 2018 4:06 pm
From what I see from what you put there, it has an Intel wi-fi 3945 abg card, not Broadcom. The Broadcom is the wired ethernet NIC.
What does "inxi -N" show in the terminal? Intel 3945s work out of the box on MX, so if you can't get it to work, I would look for some kind of hardware or software wi-fi switch that's preventing a connection. The MX Network Assistant can help with that problem. This Ubuntu thread may also help: https://ubuntuforums.org/showthread.php?t=1823149
chrispop99
Post by chrispop99 » Sat Jun 09, 2018 4:13 pm
Doh! should have read it all!
Chances are the Broadcom driver has been blacklisted. Our Network Assistant should be able to sort that out, and at least get the wired part working.
Test machines:
Post by Jerry3904 » Sat Jun 09, 2018 4:19 pm
On an old machine of mine, the wired broadcom needed b44 unblocked
Post by Stevo » Sat Jun 09, 2018 5:05 pm
Was that with both cards being Broadcom, or just the wired NIC?
Post by Jerry3904 » Sat Jun 09, 2018 5:09 pm
Both. Wireless was a b43
kmathern
Post by kmathern » Sat Jun 09, 2018 5:15 pm
kato wrote:Netgear connection[8086:4222](REV02) 03:00.0 Broadcom Corporation BCM4401-B0100 BASE-TX[14e4:1700](rev02).
The BroadcomStartup script doesn't unblacklist the 14e4:1700 wired device, it does unblacklist a 14e4:170c device https://gitlab.com/antiX-Linux/antix-go ... artup#L166
Post by Stevo » Sat Jun 09, 2018 9:37 pm
Yes, but that shouldn't affect the Intel wi-fi device, correct?
kato
#10
Post by kato » Mon Jun 11, 2018 2:21 am
I have tried everything that was suggested ,including the wireless card ,3945 ,b44 drivers ,but am unable to access the net as yet.
Would it be feasible to purchse a USB Wifi Dongle to see if I can access the Internet.
Thanks,
kato
