weird kernel issue [Solved]
Post by anticapitalista » Thu May 31, 2018 10:08 am
On my Thinkpad L412, all new antiX kernels post 4.9.91 (32 and 64 bit) boot with an xorg delay of 20-30 seconds.
If I tap the keys of the keyboard or move the mouse, it boots to desktop 'normally' with no delay.
The kernel .config is identical. The hardware is identical as are all the apps.
It happens on installed to hard drive, frugal and installed to VBox.
Corrected - Running live-usb with/without persistence seems to work ok.
Anyone got any ideas why and how to fix? Obviously something has changed in the upstream kernel.
Last edited by anticapitalista on Thu May 31, 2018 1:42 pm, edited 3 times in total.
Re: wierd kernel issue
Post by Adrian » Thu May 31, 2018 10:22 am
Does dmesg give you a clue where it gets stuck?
Post by anticapitalista » Thu May 31, 2018 10:27 am
No. dmesg shows the boot before Xorg kicks in. This part of the boot is ok. Xorg shows a delay. Here is the end of xorg.log
[    11.775] (**) Option "config_info" "udev:/sys/devices/platform/thinkpad_acpi/input/input9/event5"
[    11.775] (II) XINPUT: Adding extended input device "ThinkPad Extra Buttons" (type: KEYBOARD, id 15)
[    11.775] (**) Option "xkb_model" "pc105"
[    11.775] (**) Option "xkb_layout" "us"
[    11.775] (**) Option "xkb_options" "grp:alt_shift_toggle,terminate:ctrl_alt_bksp,grp_led:scroll"
[    11.775] (II) input device 'ThinkPad Extra Buttons', /dev/input/event5 is tagged by udev as: Keyboard
[    11.775] (II) input device 'ThinkPad Extra Buttons', /dev/input/event5 is a keyboard
[    20.809] (II) modeset(0): EDID vendor "LEN", prod id 16544
[    20.809] (II) modeset(0): Printing DDC gathered Modelines:
[    20.809] (II) modeset(0): Modeline "1366x768"x0.0   69.05  1366 1404 1426 1436  768 771 777 801 -hsync -vsync (48.1 kHz eP)
[    20.809] (II) modeset(0): Modeline "1366x768"x0.0   57.54  1366 1404 1426 1436  768 771 777 801 -hsync -vsync (40.1 kHz e)
Post by dolphin_oracle » Thu May 31, 2018 11:12 am
Is it only on the thinkpad?
lenovo ThinkPad T530 - MX-18
Post by anticapitalista » Thu May 31, 2018 11:20 am
Seems to be, yes.
The desktop doesn't show this issue.
stsoh
Re: weird kernel issue
Post by stsoh » Thu May 31, 2018 12:23 pm
try this, add
RESUME=none
to eol of /etc/initramfs-tools/initramfs.conf .
Post by anticapitalista » Thu May 31, 2018 12:31 pm
try this, add
RESUME=none
Makes no difference.
skidoo
Post by skidoo » Thu May 31, 2018 12:43 pm
the mouse movement clue suggests the delay is related to "entropy generation" -- building a random set of data for use in GPG encryption, SSL certs, etc
https://scotte.org/2015/07/TPM-for-bett ... om-entropy
haveged
tlp
rng-tools
stsoh
Post by stsoh » Thu May 31, 2018 1:04 pm
try this, add
RESUME=none
oops, kept forgetting.
u need to update initramfs.
open terminal:
sudo update-initramfs -u
reboot
#10
Post by anticapitalista » Thu May 31, 2018 1:26 pm
stsoh - I had already done that.
skidoo - You da man! I installed haveged and all is fine. Thanks!
