[Solved] PC SLow after adding 1GB Ram
vamsi
Post by vamsi » Wed May 30, 2018 7:08 am
I previously used 1 gb Ram and i added 1 extra 1 GB ram but my system is much deteriorated even though in resoures it is showing 1 gb ram use still 1 GB ram is present and i am posting the screenshot of resources
System:    Host: cherubim Kernel: 4.15.14-antix.1-686-smp-pae i686 bits: 32 Desktop: Xfce 4.12.3
           Distro: MX-17.1_386 Horizon March 12, 2017
Machine:   Type: Desktop Mobo: MICRO-STAR model: MS-7507 v: 1.0 serial: <root required>
           BIOS: American Megatrends v: 3.1 date: 03/01/2008
CPU:       Topology: Dual Core model: Intel Core2 Duo E4500 bits: 64 type: MCP
           L2 cache: 2048 KiB
           Speed: 2218 MHz min/max: N/A Core speeds (MHz): 1: 2218 2: 2218
Graphics:  Card-1: Intel 82945G/GZ Integrated Graphics driver: i915 v: kernel
           Display: x11 server: X.Org 1.19.2 driver: intel unloaded: fbdev,modesetting,vesa
           resolution: 1280x1024~75Hz
           OpenGL: renderer: Mesa DRI Intel 945G x86/MMX/SSE2 v: 2.1 Mesa 13.0.6
Audio:     Card-1: Intel NM10/ICH7 Family High Definition Audio driver: snd_hda_intel
           Sound Server: ALSA v: k4.15.14-antix.1-686-smp-pae
Network:   Card-1: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet driver: r8169
           IF: eth0 state: up speed: 100 Mbps duplex: full mac: 00:1d:92:a2:a1:ee
Drives:    HDD Total Size: 149.05 GiB used: 44.97 GiB (30.2%)
           ID-1: /dev/sda vendor: Western Digital model: WD1600AABS-00PRA0 size: 149.05 GiB
Partition: ID-1: / size: 39.12 GiB used: 20.46 GiB (52.3%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 1.91 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda1
Sensors:   System Temperatures: cpu: 69.0 C mobo: N/A
Repos:     Active apt repos in: /etc/apt/sources.list
           1: deb http://ppa.launchpad.net/canonical-chromium-builds/stage/ubuntu/ xenial main
           2: deb http://ppa.launchpad.net/nilarimogard/webupd8/ubuntu/ xenial main
           1: deb http://it.mxrepo.com/antix/stretch/ stretch main
           1: deb http://ftp.cn.debian.org/debian/ stretch-updates main contrib non-free
           1: deb http://ftp.cn.debian.org/debian/ stretch main contrib non-free
           3: deb-src http://ftp.cn.debian.org/debian/ stretch main contrib non-free
           4: deb http://deb.debian.org/debian/ stretch-backports main
           1: deb http://it.mxrepo.com/mx/repo/ stretch main non-free
           2: deb http://it.mxrepo.com/mx/testrepo/ stretch test
           Active apt repos in: /etc/apt/sources.list.d/opera-beta.list
           1: deb https://deb.opera.com/opera-beta/ stable non-free #Opera Browser (final releases)
           Active apt repos in: /etc/apt/sources.list.d/various.list
           1: deb http://deb.opera.com/opera/ stable non-free
           1: deb http://repo.vivaldi.com/stable/deb/ stable main
Info:      Processes: 182 Uptime: 8m Memory: 1.96 GiB used: 525.1 MiB (26.2%) Shell: init
           inxi: 3.0.10
Is there any other way to speed up my PC ?
cyrilus31
Re: PC SLow after adding 1GB Ram
Post by cyrilus31 » Wed May 30, 2018 7:28 am
It's not a matter of ram in use but rather a Cpu one. It is reaching almost 100% on the two cores. You should instead post the detail of processes in activity to understand why this is happening.
vamsi
Post by vamsi » Wed May 30, 2018 7:37 am
Here is the image
I only did one thing went to youtube and opened a video and the load on the cores increased like this
Thanks..
cyrilus31
Post by cyrilus31 » Wed May 30, 2018 7:50 am
Your webbrowser is clearly eating up all your cpu power.
Did you never had these slowdown before?
Take a look at this topic: YouTube on old hardware. You may find interesting ideas on how to play Youtube videos outside your browser.
vamsi
Post by vamsi » Wed May 30, 2018 7:55 am
On 1Gb ram i didn't faced this much issue after adding 1GB Ram i am facing this issue is there any alternative than smplayer ?
Because i have to open gmail and it should be opened then i need to go one website and from there only i can watch youtube videos which are private at taht time this process will not work
Thanks..
vamsi
Post by vamsi » Wed May 30, 2018 8:04 am
By the way the temperatures of my core are
sensors
coretemp-isa-0000
Adapter: ISA adapter
Core 0:       +72.0°C  (high = +86.0°C, crit = +100.0°C)
Core 1:       +70.0°C  (high = +86.0°C, crit = +100.0°C)
paul1149
Post by paul1149 » Wed May 30, 2018 8:16 am
Does the browser choke the CPU when doing things other than video?
Have you tried an alternative browser?
I don't see why more RAM would make things worse, unless the RAM were defective. I believe the Grub boot menu has a MemTest option. Otherwise you can burn a boot disk for it. Or even better, substitute a different stick of RAM. Also, sometimes RAM slots are defective, so you can try a different one if it exists. Some older MBs required RAM to go into balanced slots.
MX-17.1 x64, on C2D, 6GB RAM, SSD.
Post by Adrian » Wed May 30, 2018 8:31 am
Also remove unnecessary extensions, each separate chromium process is either a tab or an extension. Since it looks like a CPU issue it might not have anything to do with you adding 1GB RAM, is it slow if you don't open Chromium?
Post by asqwerth » Wed May 30, 2018 8:44 am
1: deb http://ppa.launchpad.net/canonical-chro ... ge/ubuntu/ xenial main
Is there an issue because he's using Chromium from a PPA? For Xenial Xerus?
vamsi
#10
Post by vamsi » Wed May 30, 2018 8:50 am
No with firefox also same issue
by the way when i open chromium it takes 2% or 3% after opening any video in youtube it reaches 95% and 100% and stabilizes at 85% 85% when i you use sm player it is just 2% and 3%
Thanks..
