Swap Around HDD (Solved)
Krissharm
Post by Krissharm » Sat May 26, 2018 6:18 pm
Hi All
Not sure this is a specific MX thing, more of a general linux thing that I can't seem to get an answer on. Hope that someone here might know what i'm talking about.
I had a my OS installed on a SATA SSD that replaced the old disk. But it occurred to me that was also an msata slot. So I installed a similar sized msata ssd in the machine, used DD to copy the orignal disk over to the new one. Then changed the boot order in the bios to the new drive. So far so good. MX is so very clever with this stuff.
However my original drive now needs me to enter the root password to mount it now at every boot. I have reformatted the drive but the problem persists. I assume there is an entry somewhere I need to add in that the drive can be mounted at boot?
Primary HP Omen 15-ax009na, i5-6300HQ+NVIDIA GTX 950 Running MX17 64 bit.
Secondary Thinkpad x220 12GB ssd msata & ssd sata drive MX17 64 bit
Light child duties Thinkpad R51 MX17/Windows XP 32bit with forcepae and IDE to SATA + Kingston SSD.
Re: Swap Around HDD
Post by dolphin_oracle » Sat May 26, 2018 6:19 pm
Hi All
I use disk-manager to set up my auto mounts. it will add entries to your fstab.
lenovo ThinkPad T530 - MX-18
Re: Swap Around HDD
Post by fehlix » Sat May 26, 2018 6:30 pm
Reformated the whole drive or only the partions ?
If you do a dd-copy from one hd/sd onto another you have also copied over the UUID of old the partitions, which will certainly will make a lot of trouble, if you leave both within the computer. You need either take on HD/SD out or remove/wipe all partions from one HD to create new partitions with new UUID's. Easiest to use Gparted to empty the disk in question!
As an expert you could assign new UUID/PUUID individually.
Krissharm
Re: Swap Around HDD
Post by Krissharm » Sat May 26, 2018 6:33 pm
Hi All
I looked there - but I couldn't see an answer. I'll have another look. Thanks
Krissharm
Re: Swap Around HDD
Post by Krissharm » Sat May 26, 2018 6:35 pm
I formatted the original drive.
So the OS was still live and is still live on the mstata device, the sata is now blank.
Re: Swap Around HDD
Post by fehlix » Sat May 26, 2018 6:43 pm
I didn't made it clear enough. You cannot format a drive! You can only format a partition! Better remove all partions an create new ones,
so you are sure you get new UUID's. But if you already got new uuid's than that might not be the cause of your problem
Richard
Re: Swap Around HDD
Post by Richard » Sat May 26, 2018 6:45 pm
Gparted offers to change the UUID of a partition so you don't have to reformat.
MX18: Lenovo T430: Intel Dual Core i5-3320M Ivy Bridge, 8GB RAM, 4.19.0-1-amd64, 119GB SSD
MX18: AsusTek EeePC 1005HA: Intel Dual Core Atom N270, 1GB RAM, 4.19.0-1-686, 150GB HDD
Krissharm
Re: Swap Around HDD
Post by Krissharm » Sat May 26, 2018 6:54 pm
Sorry - I am clearly confusing myself.
Ok so the matching UUID is the cause of my problem?
So I need to use gparted to create a new partition(S)? That should solve it.
Thank you all.
penguin
Re: Swap Around HDD
Post by penguin » Sun May 27, 2018 4:00 am
easy way to change UUID by terminal:
suppose that old UUID was: 9f4b67b5-8a7f-4c49-b1da-76c2a4040aa5
suppose that partition is: sdb3
you can change UUID on terminal :
if your sdb3 is ext4,typing on terminal as follow :
sudo tune2fs /dev/sdb3 -U 9f4b67b5-8a7f-4c49-b1da-76c2a4040aa5
if your sdbe is btfrs,typing on terminal as follow :
sudo btrfstune -U 9f4b67b5-8a7f-4c49-b1da-76c2a4040aa5 /dev/sdb3
I am not sure that if you can change UUID of a running Linux, but if so , start your laptop by a bootable Linux usb/cd or by a second Linux (if you have another one installed on your laptop).
Hope it helps.
P.S.
I have a spare part on my SD Card (12GB) and I have installed Manjaro on it.Because I experiment a lot, I used qt5-fsarchiver to backup Manjaro, installed on this sdb3 partition. When I decide to test another Linux distro on this 12 GB space , i need to format it. To come back to Manjaro , simply I use qt5-fsarchiver to have it back.....and above described lines to change UUID. For sure I can use dd command that also copies UUID, but dd command will requires much more space for backup file.
stsoh
Re: Swap Around HDD
#10
Post by stsoh » Sun May 27, 2018 4:59 am
rather than creating swap partition on ssd, use zswap n zram.
https://mxlinux.org/wiki/other/zram
oops, mistook subject.
