Interlink Versapad screenshot MX-17 and others.
tbuser48
Post by tbuser48 » Tue Jan 02, 2018 8:52 pm
For first startup from Live USB see the screenshot. Units affected are Panasonic Toughbook CF-31 MK2, MK3 and several others.
As I understand it the kernel times out (hence nomux).
This works for me to get to a desktop with a working touchpad. On a LiveUSB with persistence or hdd install there is a fix.
sudo echo "options psmouse proto=imps" | sudo tee /etc/modprobe.d/psmouse.conf >/dev/null
This creates a file /etc/modprobe.d/psmouse.conf containing "options psmouse proto=imps" (NO QUOTES)
Remember versapad is a ps/2 type "mouse". Synaptics drivers will not work. Once the psmouse.conf is saved to persistence or to a hard drive the install takes care of itself.
System: Host: mx1 Kernel: 4.13.0-1-amd64 x86_64 bits: 64 Desktop: Xfce 4.12.3
Machine: Device: laptop System: Panasonic product: CF-31JFGAA1M v: 002 serial: N/A
Mobo: Panasonic model: CF31-2 v: 1 serial: N/A
BIOS: American Megatrends v: V2.00L12 date: 08/01/2011
Battery BAT1: charge: 73.6 Wh 100.0% condition: 73.6/84.9 Wh (87%)
CPU: Dual core Intel Core i5-2520M (-MT-MCP-) cache: 3072 KB
clock speeds: max: 3200 MHz 1: 2494 MHz 2: 2494 MHz 3: 2494 MHz 4: 2494 MHz
Graphics: Card: Intel 2nd Generation Core Integrated Graphics Controller
Resolution: 1024x768@60.00hz
OpenGL: renderer: Mesa DRI Intel Sandybridge Mobile version: 3.3 Mesa 13.0.6
Audio: Card Intel 6 Series/C200 Series Family High Def. Audio Controller
driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.13.0-1-amd64
Network: Card-1: Intel 82579LM Gigabit Network Connection driver: e1000e
IF: eth0 state: down mac: 70:58:12:e1:5d:83
Card-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
IF: wlan0 state: up mac: 08:11:96:f6:93:10
Drives: HDD Total Size: 211.1GB (2.1% used)
ID-1: /dev/sda model: INTEL_SSDSC2CT18 size: 180.0GB
ID-2: USB /dev/sdb model: DataTraveler_3.0 size: 31.0GB
Partition: ID-1: / size: 4.6G used: 13M (1%) fs: overlay dev: N/A
ID-2: swap-1 size: 3.08GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors: System Temperatures: cpu: 49.4C mobo: 49.4C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 203 Uptime: 3 min Memory: 431.1/5857.5MB Client: Shell (bash) inxi: 2.3.53
Eadwine: Edited title, please don't shout
