-- Change in MX sources
-- antiX-17 release info here
HPLIP 3.17.x
rasat
HPLIP 3.17.x
#1 Post by rasat » Sat Dec 30, 2017 9:12 am
To install hplip 3.17.x requires following packages:
pyqt5-dbus
libcrypto
libnetsnmp-devel
sane-devel
pyqt4-dbus
python-devel
cups-devel
python-dbus
pyqt5
libusb
libtool
cups-image
libjpeg
dbus
What repo to use?
Paul..
Re: HPLIP 3.17.x
#2 Post by Paul.. » Sat Dec 30, 2017 9:19 am
If you use MX-Tools->Package Installer->then select Printing->then select HP Printing Extras...you will install HPLIP-3.16.11
Any particular reason you need HPLIP 3.17.x?
Daily: MSI 890FXA-GD70 | AMD Phenom II X6 1055T | GeForce GTX 750 Ti | 8G
Test: Thinkpad T431s | Intel i5-3437U | Intel 3rd gen Graphics | 4G
Re: HPLIP 3.17.x
#3 Post by Stevo » Sat Dec 30, 2017 2:40 pm
rasat wrote:To install hplip 3.17.x requires following packages:
pyqt5-dbus
libcrypto
libnetsnmp-devel
sane-devel
pyqt4-dbus
python-devel
cups-devel
python-dbus
pyqt5
libusb
libtool
cups-image
libjpeg
dbus
What repo to use?
You are reading the guide for non-Debian distros such as Fedora. You need to read the Debian guide. All the packages are available in the standard repository, but often will be named differently in Debian...libcups2-dev instead of cups-devel is one example. But as Paul says, your printer might already be supported.
rasat
Re: HPLIP 3.17.x
#4 Post by rasat » Sat Dec 30, 2017 3:08 pm
HP-LaserJet-Pro-MFP-M125a requires HP 3.17. Netrunner Linux with Depian 8 had the same issue and was solved by using testing stretch repo.
I was expecting MX 17 with Debian 9.3, solved the issue. I will temporarily enable testing.
Re: HPLIP 3.17.x
#5 Post by Stevo » Sat Dec 30, 2017 3:58 pm
rasat wrote:HP-LaserJet-Pro-MFP-M125a requires HP 3.17. Netrunner Linux with Depian 8 had the same issue and was solved by using testing stretch repo.
Don't add the Debian testing repository, please. That often breaks your install beyond repair. We're going to get some version of 3.17.X in our own test repo, which doesn't break things. We have 3.17.6 already in the Debian 8 based MX 15/16 test repo, so it's not impossible, though Debian seems to have made versions >= 3.17.7-2 unbackportable.
rasat
Re: HPLIP 3.17.x
#6 Post by rasat » Sat Dec 30, 2017 4:08 pm
Thanks. I found out that the repo I used before, does not help.
https://wiki.debian.org/DebianExperimental
Re: HPLIP 3.17.x
#7 Post by Stevo » Sat Dec 30, 2017 4:14 pm
rasat wrote:Thanks. I found out that the repo I used before, does not help.
That usually does more harm than good.
HP says the 125a only needs 3.14.3: https://developers.hp.com/hp-linux-imag ... lugin.html
Do you mean you have the 25a?
These printers also require that you download and install a proprietary plugin from HP to work, as far as I gather.
Re: HPLIP 3.17.x
#8 Post by Stevo » Thu Jan 11, 2018 7:58 pm
To bring this to a conclusion, solved the problem with the backports since 3.17.7-2. A real face-palm moment--it just needs a non-parallel build, but the switch to debhelper 10 made parallel builds the default.
Re: HPLIP 3.17.x
#9 Post by timkb4cq » Thu Jan 11, 2018 9:17 pm
Thought I had tried that - but I just left off the -j3 instead of forcing it. :duh:
Re: HPLIP 3.17.x
#10 Post by Stevo » Thu Jan 11, 2018 10:40 pm
timkb4cq wrote:Thought I had tried that - but I just left off the -j3 instead of forcing it. :duh:
I suppose building with -j1 would also do it, but I decided to lock it down in the rules file. I think Buster can do the parallel build, though. Let me run that through my Buster pbuild.
Update: yes, Buster has no problem with the parallel build. Just a gotcha for the intrepid backporter, it seems.
