-- Change in MX sources
-- antiX-17 release info here
[SOLVED] TP-Link TL-WN722N poor usb wifi performance
dr-kart
#1 Post by dr-kart » Mon Dec 25, 2017 1:45 pm
On my MX17x64 I had noticed bit performance decrease in bandwidth since I still got manjaro installed on other partition to compare in case. Did not pay much attention though. Today another test - warthunder online game - proved I might have an issue. Namely connection wasn't stable with ping varying from 40 up to 500 ms. Which isn't the case with arch. Tested on different game's servers.
Kernel: 4.14.8-antix.1-amd64-smp
inxi -N
Network:   Card: Atheros AR9271 802.11n driver: ath9k_htc
modinfo ath9k_htc
filename:       /lib/modules/4.14.8-antix.1-amd64-smp/kernel/drivers/net/wireless/ath/ath9k/ath9k_htc.ko
firmware:       ath9k_htc/htc_9271-1.4.0.fw
firmware:       ath9k_htc/htc_7010-1.4.0.fw
description:    Atheros driver 802.11n HTC based wireless devices
vermagic:       4.14.8-antix.1-amd64-smp SMP preempt mod_unload modversions
parm:           debug:Debugging mask (uint)
parm:           nohwcrypt:Disable hardware encryption (int)
parm:           btcoex_enable:Enable wifi-BT coexistence (int)
parm:           ps_enable:Enable WLAN PowerSave (int)
parm:           use_dev_fw:Use development FW version (int)
mandatory tweak in my case:
/etc/modprobe.d/ath9k_htc.conf
options ath9k_htc nohwcrypt=1
just in case even added to /etc/NetworkManager/NetworkManager.conf
[device]
wifi.scan-rand-mac-address=no
apt-cache policy firmware-atheros
firmware-atheros:
  Installed: 20170823-1mx17+1
  Candidate: 20170823-1mx17+1
  Version table:
 *** 20170823-1mx17+1 500
        500 http://mxrepo.com/mx/repo stretch/non-free amd64 Packages
        500 http://mxrepo.com/mx/repo stretch/non-free i386 Packages
        100 /var/lib/dpkg/status
     20161130-3 500
* Debian backports tab has firmware-atheros (20170823-1~bpo9+1) marked as available to update. :confused: But I failed to update it via mx-packageinstaller
Re: TP-Link TL-WN722N usb wifi performance
#2 Post by timkb4cq » Mon Dec 25, 2017 2:02 pm
It's not an update. The debian-backports atheros firmware is exactly version the same as comes installed in MX-17.
If the wifi is more stable under Manjaro, it would make sense to compare the settings and package versions in that distro so we can see where they differ.
dr-kart
#3 Post by dr-kart » Mon Dec 25, 2017 2:52 pm
manjaro looks pretty much the same here.
Network:   Card: Qualcomm Atheros AR9271 802.11n driver: ath9k_htc
filename:       /lib/modules/4.14.8-1-MANJARO/kernel/drivers/net/wireless/ath/ath9k/ath9k_htc.ko.xz
license:        Dual BSD/GPL
author:         Atheros Communications
srcversion:     83D534D14C5654C0D7069FE
depends:        mac80211,ath9k_hw,ath9k_common,ath,cfg80211,usbcore,led-class
intree:         Y
vermagic:       4.14.8-1-MANJARO SMP preempt mod_unload modversions
Don't know what else I need to look at.
I see the same version dates. But why I wasn't able to install backported one? That's weird.
#4 Post by dolphin_oracle » Mon Dec 25, 2017 2:58 pm
you may want to post the log at /var/log/mxpi.log and mxpi.log.old . there may be clues present.
I actually just tried it, and apt see our package in the mx repo has a newer version, so you get that.
lenovo ThinkPad T530 - MX-17
dr-kart
#5 Post by dr-kart » Mon Dec 25, 2017 3:05 pm
@dolphin_oracle Oh I see, thank you!
mxpi.log says that the size is not valid.
dr-kart
Re: [SOLVED] TP-Link TL-WN722N poor usb wifi performance
#6 Post by dr-kart » Tue Dec 26, 2017 7:04 pm
:idea: Culprit is found.
it is current network manager!
I just tried to use ceni instead. And everything is ok now.
Seems like NM needs to be updated/fixed.
#7 Post by richb » Tue Dec 26, 2017 7:08 pm
Works fine for me.
Rich
SSD Production: MX 17.1
dr-kart
#8 Post by dr-kart » Tue Dec 26, 2017 7:13 pm
NM does work. But not perfect if you have wifi via ath9k module at least. I can confirm that I have performance issue with it so far. Ceni is ok.
#9 Post by Jerry3904 » Tue Dec 26, 2017 7:15 pm
I am using that module on my testing machine, and NM works fine here as well.
#10 Post by richb » Tue Dec 26, 2017 7:35 pm
I have a TP Link card installed in my computer, not a dongle, using the ath9k module. But I am using the standard 4.13 kernel and atheros driver.
Rich
