-- Change in MX sources
-- antiX-17 release info here
External HDD For my MX Linux
vamsi
#1 Post by vamsi » Sat Dec 23, 2017 4:43 pm
System:    Host: cherubim Kernel: 4.13.0-1-686-pae i686 bits: 32 Desktop: Xfce 4.12.3
           Distro: MX-17_386 Horizon December 15, 2017
Machine:   Device: desktop Mobo: MICRO-STAR model: MS-7507 v: 1.0 serial: N/A
           BIOS: American Megatrends v: V3.1 date: 03/01/2008
CPU:       Dual core Intel Core2 Duo E4500 (-MCP-) cache: 2048 KB
           clock speeds: max: 2218 MHz 1: 2218 MHz 2: 2218 MHz
Graphics:  Card: Intel 82945G/GZ Integrated Graphics Controller
           Display Server: x11 (X.Org 1.19.2 ) drivers: intel (unloaded: modesetting,fbdev,vesa)
           Resolution: 1280x1024@75.02hz
           OpenGL: renderer: Mesa DRI Intel 945G x86/MMX/SSE2 version: 2.1 Mesa 13.0.6
Audio:     Card Intel NM10/ICH7 Family High Def. Audio Controller driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k4.13.0-1-686-pae
Network:   Card: Realtek RTL8101/2/6E PCIE Fast/Gigabit Ethernet controller driver: r8169
           IF: eth0 state: up speed: 100 Mbps duplex: full mac: 00:1d:92:a2:a1:ee
Drives:    HDD Total Size: 160.0GB (14.1% used)
           ID-1: /dev/sda model: WDC_WD1600AABS size: 160.0GB
Partition: ID-1: / size: 27G used: 20G (76%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 2.05GB used: 0.19GB (9%) fs: swap dev: /dev/sda1
Sensors:   System Temperatures: cpu: 61.0C mobo: N/A
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 185 Uptime: 1:25 Memory: 612.3/996.2MB Client: Shell (bash) inxi: 2.3.53
I was planning to buy a 1 TB External HDD for MX linux and these are my specs and i got
Do I need more ram to use external HDD
Do i need to configure anything in MX linux to use external HDD in amazon i had seen some HDD's and on one of them it shows that it supports LINUX MAC Windows is it like connecting Pendrive to a PC?
Any other tips before buying External HDD
Thanks..
csaenemy
Re: External HDD For my MX Linux
#2 Post by csaenemy » Sat Dec 23, 2017 4:54 pm
This should work absolutely fine in just the same way as a flash drive, just mount using thunar. The only problem I've ever had was trying to use with raspberry pi which just resulted in the drive clicking. I had an external drive with independent power supply in the past which worked with anything.
Gordon Cooper
#3 Post by Gordon Cooper » Sat Dec 23, 2017 5:13 pm
Have been using an external 1TB HDD for a couple of years. It has a separate power supply and mounts with thunar when i need it.
Homebrew64 bit Intel duo core 2 GB RAM, 120 GB Kingston SSD, Seagate1TB.
Primary OS : MX-17.1 64bit. Also MX17, Kubuntu14.04 & Puppy 6.3.
Dell9010, MX-17.1, Win7
uncle mark
#4 Post by uncle mark » Sat Dec 23, 2017 5:13 pm
Buy something like this and use your own hard drive:
https://www.newegg.com/Product/Product. ... -_-Product
Desktop: Custom build Asus/AMD/nVidia -- MEPIS 11
Laptop: Acer Aspire 5250 -- MX-15
Assorted junk: assorted Linuxes
vamsi
#5 Post by vamsi » Sat Dec 23, 2017 5:19 pm
Gordon Cooper wrote:Have been using an external 1TB HDD for a couple of years. It has a separate power supply and mounts with thunar when i need it.
separate power supply is it not plug and play option ?
#6 Post by Jerry3904 » Sat Dec 23, 2017 5:21 pm
Ha! You recommended that to me a couple of years ago for a drive I took from another machine, and it has been working very well.
LnoyBoy
#7 Post by LnoyBoy » Sat Dec 23, 2017 5:33 pm
If the external hard drive does not have its own power supply , it may have a
Double USB type cord. So you would need two available USB ports to plug it in.
old_guy
#8 Post by old_guy » Sat Dec 23, 2017 5:42 pm
vamsi the Thermaltake External Hard Drive SATA Enclosure Docking Station that uncle mark points out is a good idea, but the link goes to a USB 2 model. I would get a USB 3 model - much greater speed! I have used Thermaltake USB 3 Docking Station for awhile - they make a solid device.
Earl
Mauser
#9 Post by Mauser » Sat Dec 23, 2017 7:15 pm
RAM is not an issue. All you need is an external HDD and plug in the power and plug in the USB and it will show up automatically in Thunar. I use a 4TB External Western Digital HDD for backups from my 4TB internal Western Digital HDD.
vamsi
#10 Post by vamsi » Sun Dec 24, 2017 1:41 pm
Mauser wrote:RAM is not an issue. All you need is an external HDD and plug in the power and plug in the USB and it will show up automatically in Thunar. I use a 4TB External Western Digital HDD for backups from my 4TB internal Western Digital HDD.
Thanks for the reply
After searching in amazon i found these hdd's. But the biggest doubt is the first two of them in the description box it is said that DDR3 SDRAM (Particulary AdATA and WesternDigital Company Hdd's see the link 1 and 2)but i don't have that type of ram will it work (See Screenshot) and in the 3 and 4 one i haven't see such type of thing
Which one will be good among these?
1) https://goo.gl/WxCmh4
2) https://goo.gl/kkY6GN
3) https://goo.gl/i5PtrH
4) https://goo.gl/2E2gT7
Thanks..
