ROM drive doesn't work. [Solved]
Mauser
Post by Mauser » Sat Dec 23, 2017 12:36 pm
ROM drive worked on MX-16.1 but doesn't work on MX-17. I found all the commands are missing in Removable Drives and Media. What commands I put in there? Unfortunately I can't post a screen shot of what I am talking about because image sites are not working.
Kernel: 4.13.0-1-amd64 x86_64 bits: 64 Desktop: Xfce 4.12.3
Machine:   Device: desktop System: HP product: 510-p026 serial: N/A
           Mobo: HP model: 81B4 v: 00 serial: N/A UEFI [Legacy]: AMI v: F.13 date: 08/02/2016
CPU:       Quad core Intel Core i5-6400T (-MCP-) cache: 6144 KB
           clock speeds: max: 2800 MHz 1: 2200 MHz 2: 2200 MHz 3: 2200 MHz 4: 2200 MHz
Graphics:  Card: Intel HD Graphics 530
           Resolution: 1366x768@59.81hz, 1920x1080@60.00hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 530 (Skylake GT2) version: 4.5 Mesa 13.0.6
Audio:     Card Intel Sunrise Point-H HD Audio driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k4.13.0-1-amd64
Network:   Card-1: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller driver: r8169
           IF: eth0 state: up speed: 100 Mbps duplex: full mac: ec:8e:b5:d8:80:88
           Card-2: Intel Wireless 3165 driver: iwlwifi
           IF: wlan0 state: down mac: 2e:c0:f9:c5:2b:e7
Drives:    HDD Total Size: 8001.5GB (27.4% used)
           ID-1: /dev/sda model: WDC_WD4003FZEX size: 4000.8GB
           ID-2: USB /dev/sdb model: Elements_107C size: 4000.8GB
Partition: ID-1: / size: 3.6T used: 655G (19%) fs: ext4 dev: /dev/sda3
           ID-2: swap-1 size: 12.90GB used: 0.39GB (3%) fs: swap dev: /dev/dm-0
Sensors:   System Temperatures: cpu: 30.0C mobo: 27.8C
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 230 Uptime: 21:49 Memory: 2279.9/11881.1MB Client: Shell (bash) inxi: 2.3.53
I am command line illiterate. :confused:
Re: ROM drive doesn't work.
Post by Jerry3904 » Sat Dec 23, 2017 12:57 pm
Have long since you did an upgrade? I ask because a solution to this problem has been worked out and made available.
Mauser
Post by Mauser » Sat Dec 23, 2017 1:04 pm
Jerry3904 wrote:Have long since you did an upgrade? I ask because a solution to this problem has been worked out and made available.
Dec. 17. I also did the update today.
Post by anticapitalista » Sat Dec 23, 2017 1:08 pm
Have you rebooted? The change needs a reboot.
Mauser
Post by Mauser » Sat Dec 23, 2017 1:15 pm
anticapitalista wrote:Have you rebooted? The change needs a reboot.
Yes, it still doesn't worked. I checked into Removable Drives and Media and it still shows nothing filled in. What goes in all them boxes?
Post by dolphin_oracle » Sat Dec 23, 2017 3:13 pm
nothing has to be filled in removable drives and media. those are areas for you to specify apps to open after the media is detected. by default its thunar.
please post the output of
ll /etc/udev/rules.d
that's 2 lower case L
also, can you mount the cd rom drive using Disk Manager. And what sort of disk are you using (video, music, data)
lenovo ThinkPad T530 - MX-18
Mauser
Post by Mauser » Sat Dec 23, 2017 3:53 pm
I tried the same DVD on my laptop that has MX-17 and the same problem. I found the problem. Xfburn burned a bad DVD. It was so bad that it didn't show anything in Thunar. Thinking back, Xfburn did the same thing on an other Linux distro I used in the past. I am going to look for a reliable burner program. Thanks and sorry for the post. Merry Christmas all.
