Revisiting a laptop bluetooth issue
rover
Post by rover » Sun Dec 17, 2017 4:38 am
Hi everyone !
Following advice from this post http://forum.mxlinux.org/viewtopic.php? ... d42ddd3d54, i've waited
for MX-17 release to test again on a Lenovo G50-45 laptop.
Unfortunately ,the issue persists .Once again inxi -F output for the device is
Host: mx1 Kernel: 4.13.0-1-amd64 x86_64 bits: 64 Desktop: Xfce 4.12.3
Machine:   Device: laptop System: LENOVO product: 80E3 v: Lenovo G50-45 serial: N/A
           Mobo: LENOVO model: Lancer 5B2 serial: N/A UEFI: LENOVO v: A2CN24WW(V1.06) date: 07/09/2014
Battery    BAT1: charge: 18.0 Wh 65.0% condition: 27.7/31.7 Wh (87%)
CPU:       Dual core AMD E1-6010 APU with AMD Radeon R2 Graphics (-MCP-) cache: 1024 KB
           clock speeds: max: 1350 MHz 1: 1350 MHz 2: 1000 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Mullins [Radeon R2 Graphics]
           Display Server: x11 (X.Org 1.19.2 ) drivers: ati,radeon (unloaded: modesetting,fbdev,vesa)
           Resolution: 1366x768@60.00hz
           OpenGL: renderer: Gallium 0.4 on AMD MULLINS (DRM 2.50.0 / 4.13.0-1-amd64, LLVM 3.9.1)
           version: 4.3 Mesa 13.0.6
Audio:     Card-1 Advanced Micro Devices [AMD] FCH Azalia Controller driver: snd_hda_intel
           Card-2 Advanced Micro Devices [AMD/ATI] Kabini HDMI/DP Audio driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k4.13.0-1-amd64
Network:   Card-1: Realtek RTL8723BE PCIe Wireless Network Adapter driver: rtl8723be
           IF: wlan0 state: up mac: ec:0e:c4:61:c5:7d
           Card-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169
           IF: eth0 state: down mac: 28:d2:44:d6:5c:6e
Drives:    HDD Total Size: 1016.2GB (0.3% used)
           ID-1: /dev/sda model: ST1000LM024_HN size: 1000.2GB
           ID-2: USB /dev/sdb model: USB_Flash_Drive size: 16.0GB
Partition: ID-1: / size: 2.7G used: 365M (14%) fs: overlay dev: N/A
           ID-2: swap-1 size: 3.72GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 47.2C mobo: N/A gpu: 47.0
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 169 Uptime: 19 min Memory: 969.0/3411.4MB Client: Shell (bash) inxi: 2.3.53
So when i activate bluetooth manager and search for devices i get this error
Image[/img]
I know that this has something to do with the particular laptop , because testing on my windows laptop ( an older clevo w253) bluetooth works as intended.
If anyone can provide any advice over this i 'll gladly welcome it , and of course provide any other necessary information .
Best Regards
Re: Revisiting a laptop bluetooth issue
Post by Jerry3904 » Sun Dec 17, 2017 6:05 am
Please run this in a terminal and report back what it says:
hcitool dev
rover
Post by rover » Sun Dec 17, 2017 7:51 am
demo@mx1:~
$ hcitool dev
Devices:
Hope this helps
Best Regards
Post by Jerry3904 » Sun Dec 17, 2017 8:06 am
Well it indicates that your BT device is not working. Here's what I get:
$ hcitool dev
Devices:
	hci0	00:02:72:39:B5:58
I have a disfunctional one on my testing machine, so just bought a cheap BT dongle and it works fine. There's lots of them out there--I use a Kinivo, currently on US Amazon for about $13, and there are other good ones for even a few dollars less.
Post by Jerry3904 » Sun Dec 17, 2017 8:16 am
Let me check:
--do you see a BT icon in the Notification Area?
--if yes, when you click on it do you get an option to enable BT?
rover
Post by rover » Sun Dec 17, 2017 8:26 am
Thank you for the reply .
I find odd that rfkill list outpout
$ rfkill list
0: ideapad_wlan: Wireless LAN
	Soft blocked: no
	Hard blocked: no
1: ideapad_bluetooth: Bluetooth
	Soft blocked: no
	Hard blocked: no
2: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
3: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
does not seem to indicate that the device is blocked (if i interpret correctly ! )
And bluetoothctl commands give this output
[bluetooth]# power on
Failed to set power on: org.bluez.Error.Failed
[bluetooth]# scan on
Failed to start discovery: org.bluez.Error.NotReady
Appreciate your help .
Best Regards
rover
Post by rover » Sun Dec 17, 2017 8:40 am
Yes there is an icon and when i select the bluetooth on option nothing happens ,the icon remains gray( and iirc it is supposed to turn blue) and options in the right click menu are greyed out.
Hope this helps
Best Regards
mistr
Post by mistr » Wed Jan 24, 2018 11:22 am
I have the same problem on a HP laptop (xini -F) Machine: Device: laptop System: HP product: HP Notebook v: Type1ProductConfigId serial: N/A
Mobo: HP model: 81EE v: 62.39 serial: N/A UEFI: Insyde v: F.24 date: 01/20/2017
The bluetoothicon shows up but does not turn white when i select turn on bluetooth.
With dmesg I get the ouput "hci0 urb ffff9342f35f70c0 failed to resubmit (113)" after trying to turn on bluetooth and after log in as user
output of rfkill list all =
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Here are some error-messages of dmesg relating to bluetooth:
platform MSFT0101:00: failed to claim resource 1: [mem 0xfed40000-0xfed40fff]
acpi MSFT0101:00: platform device creation failed: -16 (don't know if those two messages relate to BT)
Bluetooth: hci0: rtl: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_config.bin
bluetooth hci0: firmware: failed to load rtl_bt/rtl8723b_config.bin (-2)
bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_fw.bin
Have I to install some special firmware to get bluetooth to work?
Thanks for your help in advance
MiCHAEL
