Hello, my printer has been working fine but has recently stopped. I get print error message; "There was a problem processing the document". I've tried deleting the printer then installing again, reinstalling hplip but no joy. The scanner works fine & I can use it as a copier so I don't think the printer is faulty.
Can anyone help please?
NewsCurrent releasesNew users
- Please read this first, and don't forget to add system and hardware information to posts!
- Read Forum Rules
HP Laserjet Pro M125nw stopped working
Re: HP Laserjet Pro M125nw stopped working
Do you know if you ran updates prior to the problem arising?
In my experience, on more than one occasion HPLIP updates have caused issues with different HP printers.
What I now do is lock the HPLIP version (via Synaptic) on a working install.
Try reverting to an older version of HPLIP or maybe a newer update might fix the problem.
Mike
Mike
TOSHIBA Satellite Pro C850
Distro: MX-15_x64 Fusion 24 December 2015
Dual core Intel Core i3-2350M
Intel 2nd Generation Core Processor Family Integrated Graphics Controller
Intel 7 Series/C210 Series Family High Definition Audio Controller
Thanks Mike, yes I'm pretty sure it was due to updates.
How do I install an older version of HPlip?
- Eadwine Rose
- Forum Veteran
Have you checked to see if the printer is enabled?
Under print settings - configure printers (in the menu) you can see your printer. Right click on it and check if there is a checkmark next to enabled. If not, click on it to enable the printer.
MX-17.1_x64 Horizon 14-3-2018 * 4.15.0-1-amd64 ext4 Xfce 4.12.3 * AMD Asus M4A785TD-V EVO AM3 * ASUS GF GT640-1GD5-L NVIDIA 384.111 * AMD Proc. Athl II X4 635, sAM3 * HDA ATI SB VT1708S An * 2x4Gb DDR3 1600 Kingst * 22" Samsung SyncM P2250 * HP F2280
Yes thanks, printer is enabled.
How do I install an older hplip package?
Please see Section 5.3.2 of the Users Manual.
I followed the manual but it installs the latest version even when I force it.
what is the output of Also: you have to pin the lower package (next section in the Manual) or it will be immediately upgraded again.
apt-cache policy hplip
Hplip in MX-15 / MX-16 main hasn't been been updated since May.
The version in the testing repository (which you shouldn't leave active) was last updated July 9
So if this was due to a recent update, it's likely not the hplip package that's responsible.
If you're running version 3.16.11 then you have the version in the MX main repositories.
If you're running version 3.17.6 then you have the version in the MX testing repositories.
If you're running version 3.14.6 then you have the version in the debian repositories.
Jerry3904 wrote:what is the output ofAlso: you have to pin the lower package (next section in the Manual) or it will be immediately upgraded again.Code: Select all
$ apt-cache policy hplip
hplip:
Installed: 3.16.11+repack0-1mx15+1
Candidate: 3.16.11+repack0-1mx15+1
Version table:
*** 3.16.11+repack0-1mx15+1 0
500 http://mxrepo.com/mx/repo/ mx15/main amd64 Packages
100 /var/lib/dpkg/status
3.16.10+repack0-1mx15+1 0
500 http://mxrepo.com/mx/repo/ mx16/main amd64 Packages
3.14.6-1+deb8u1 0
500 http://ftp.us.debian.org/debian/ jessie/main amd64 Packages
Who is online
Users browsing this forum: No registered users and 4 guests
