-- Change in MX sources
-- antiX-17 release info here
Mounting 8tb HDD requires root pwd?
jbloggs
#1 Post by jbloggs » Fri Aug 11, 2017 7:34 pm
I'm running MX -16 x64 (XFCE) from a 16 gb Lexar Plug'n'Stay usb thumb drive.
I have an 8tb HDD which is in a hot-swap bay.
When I connect this drive MX requires the root password. Permissions are correct ( same user-name etc as thumb drive)
Have MX on my laptop and my main PC ( HDD installs) and have had it on the PC in question on an old HDD. All work fine - no need for root password to access other drives.
Suggestions?
Thanks
Re: Mounting 8tb HDD requires root pwd?
#2 Post by Stevo » Fri Aug 11, 2017 7:38 pm
I'm pretty sure you can get rid of the password by adding the drive in disk-manager.
#3 Post by dolphin_oracle » Fri Aug 11, 2017 10:02 pm
jbloggs wrote:I'm running MX -16 x64 (XFCE) from a 16 gb Lexar Plug'n'Stay usb thumb drive.
Suggestions?
Thanks
some more info would be good.
how is the thumb drive formated?
how is the HDD formated?
can the "installed" MX utilize the drive in the hot swap bay without the root password? If so, is this drive defined in fstab and if so, please post the contents of the fstab.
Its quite possible that the thumb drive, which udev will determine is removable, is mountable as a user but that HDD is showing up as an "internal" non-removable drive, which by default requires root access, or at least some setup for user access, depending on how the drive is formatted.
lenovo ThinkPad T530 - MX-17
jbloggs
#4 Post by jbloggs » Sat Aug 12, 2017 10:34 pm
Thanks for replies
info hereunder:-
From GParted
Model : Lexar USB Flash Drive
Size 14.91 GiB
Path /dev/sda1
Partition Table msdos
heads 255
sectors/track 63
Cylinders 1945
Total Sectors 31258624
Sector Size 512
Partitions
/dev/sda1 ext4 12.87 GiB
/dev/sda2 Linux swap 2.03 Gib
8 TB HDD from GPARTED
Model : ATA ST8000VN0022-2EL
Size 7.28TB
Path /dev/sdb
Partition Table
heads 255
sectors/track 63
Cylinders 972801
Total Sectors 15628053168
Sector Size 512
Partitions
/dev/sdb1 8TB file system ext4
partition table is btrfs
/etc/fstab
The inserted Volume was mounted Automatically
( but still requires root pwd to access hdd)
/dev/sdc1 / auto defaults,noatime 1 1 (not /sda1 as per gparted)
/dev/sdc2 swap swap defaults 0 0
Anti-x-16.1-x64 live cd - no need for password to access 8-TB-hdd
jbloggs
#5 Post by jbloggs » Sat Aug 26, 2017 4:02 am
OK, no replies.
Found this
https://mxlinux.org/wiki/system/mount-i ... t-password
Mount internal partition without using root password
Version: MX-15
Section:
System
By default, the gvfs/udisks2 stack requires a root/superuser password when mounting internal partitions. Setting the "user" option in your /etc/fstab file will not change this behavior in the gui (by default, Thunar) file managers that utilize gvfs and/or udisks2.
Authentication for udisks2 is handled with policy kit. If you wish to override the default behavior of requiring a root/superuser password, then paste the contents below into a file called
/etc/polkit-1/localauthority/50-local.d/50-udisks.pkla
to allow any user in the "users" group to mount partitions without a root/superuser password. Changes should take place immediately. Note that this will NOT override the filesystem permissions.
Content of new file /etc/polkit-1/localauthority/50-local.d/50-udisks.pkla
Code:
[udisks]
Identity=unix-group:users
Action=org.freedesktop.udisks*
ResultAny=yes
ResultInactive=no
ResultActive=yes
works - mounts partitions and opens each of them in a separate fle manager window. Need them to be available to mount without entering either root or user passwd, and to not auto-open in file manager.
Advice please.
#6 Post by Jerry3904 » Sat Aug 26, 2017 5:59 am
Thunar does that by default, but you can change it (I always do): Start menu > "Removable Drives and Media," Storage tab: uncheck the auto options you don't want.
Does that do it for you?
BTW: good job on finding the Wiki entry!
stsoh
#7 Post by stsoh » Sun Aug 27, 2017 1:22 am
jbloggs wrote:.......
Code:
[udisks]
ResultAny=yes
ResultInactive=no
ResultActive=yes
wow, this is great, getting more user friendly (main reason is user friendly).
i hope mx dev add this and also get rid of tumbler for future mx developments.
MX-17.1_x64 Horizon, G41M-P33 Combo(MS-7592), Pentium E5400 (min/max: 1203/2700 MHz), 8Gb RAM (800 MT/s),
