swap not auto mounting at boot- SOLVED
entropyfoe
Post by entropyfoe » Fri Aug 26, 2016 10:02 pm
Not the sig machine, but a replaced MB Asus A88XM-A. I installed MX-15 a while back on this machine, but did not use it as it is the "spare " machine. But I forgot that swap was not working, and I rediscovered this with the new MB.
I try and run swapon as root and get this
music@X2:~
$ su root
Password:
root@X2:/home/music# swapon -a
swapon: cannot find the device for UUID=84f9afea-dd97-4937-9930-36fdb39a1b7b
gparted sees the swap partition, but it is not activated. I right click the swap partition and do the swapon, and then it is activated (the little disk symbol is next to the partition). And top shows the swap. But that does not persist if I reboot. How do I make that stick?
cannot find the device for uuid=84.....
That is indeed the uuid of the swap partition
here is fstab
# /etc/fstab: static file system information.
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
#Entry for /dev/sda1 :
UUID=bed91853-9ebf-4004-b634-4613b7e1d39b	/	auto	defaults,noatime	1	1
#Entry for /dev/sdb1 :
UUID=777651e2-a4af-494b-a218-055ca66a8246	/media/sdb1	ext3	defaults	0	2
#Entry for /dev/sdc1 :
UUID=B6147CA3147C67EF	/media/music/backup_disk	ntfs	defaults,nodev,nosuid,uid=1000,gid=1000,dmask=0077,fmask=0177,uhelper=udisks2	0	0
#Entry for /dev/sda3 :
UUID=9d41fa8e-ec70-4755-b828-9a8cdde5bd29	/home	auto	defaults,noatime	1	2
UUID=84f9afea-dd97-4937-9930-36fdb39a1b7b	swap	swap	defaults	0	0
Thanks !
Asus Prime 370X-Pro
AMD Ryzen 1600X (12 threads @ 3.6 GHz)
16 Gig DDR4 3200 (G Skill)
Nvidia -MSI GeForce GT 710 fanless
Samsung 960 NVMe SSD nvme0n1 P1-3=MX-18, P4=MX 18
1TB SSD sda1= Data, 2TB WD =backups
on-board ethernet & sound
BitJam
Re: swap not auto mounting at boot
Post by BitJam » Fri Aug 26, 2016 10:21 pm
Maybe you have the wrong UUID in the fstab. Check it with:
sudo lsblk -o name,fstype,uuid
Will I cry when it's all over?
When I die will I see Heaven?
entropyfoe
Post by entropyfoe » Fri Aug 26, 2016 11:31 pm
bitjam,
yup, I think that is it
I get the uuid of cc6ee24a-3794-42f3-9cb0-e1dc16e63bba
but fstab somehow had cannot find the device for UUID=84f9afea-dd97-4937-9930-36fdb39a1b7b
So I put in the number your command found.
I will reboot and see if it has swap on.
Let's see....
Asus Prime 370X-Pro
entropyfoe
Post by entropyfoe » Fri Aug 26, 2016 11:46 pm
yup, that fixes it. I rerbooted and swap is there.
I still don't know how that uuid got in during the install. I certainly would not have typed in all those numbers !?!?!
Thanks for the quick insight on how to find the discrepancy.
That shows the power of this forum and the helpful people here.
Asus Prime 370X-Pro
oops
Re: swap not auto mounting at boot- SOLVED
Post by oops » Wed May 30, 2018 2:55 pm
music@X2:~
$ su root
Password:
here is fstab
Thanks !
Thanks too,
I had the same issue, and with EFI partition too.
UUID=B4C01-87F4	/boot/efi	vfat	defaults,noatime,nodiratime	0	1
mount -a # to reload the fstab
mount # to list
swapon -a
cat /proc/swaps # to list swap
sunrat
Post by sunrat » Wed May 30, 2018 9:34 pm
It happens easily in a multi-boot. Installing a new OS will often reformat the swap thus giving it a new UUID.
I recently did a Stretch netinstall and the only way to avoid it reformatting swap was to not designate a swap partition during install and add it later from the installed system.
