Issues where Wifi loses internet but not connection
cmscritic
Post by cmscritic » Tue Jun 12, 2018 10:20 am
I'm having frustrating issues where my laptop for some reason loses internet connectivity but stays connected to the wifi. If I leave the laptop for an extended period (or sometimes in the middle of working) the connection will stop working and I have to switch to another wifi network and then back in order to get it functional again.
Things I've tried include adding DNS servers from dns.watch to my connection and rebooting but nothing seems to work. Power savings says it is off as well so I can't see that being the issue.
Thoughts on how I can troubleshoot?
turtlebay777
Re: Issues where Wifi loses internet but not connection
Post by turtlebay777 » Tue Jun 12, 2018 12:48 pm
Does your modem/router have a power saving mode?
cmscritic
Post by cmscritic » Tue Jun 12, 2018 1:55 pm
No it doesn’t
chrispop99
Post by chrispop99 » Tue Jun 12, 2018 2:02 pm
Hello, welcome to the forum.
Are you running live, or installed?
Test machines:
cmscritic
Post by cmscritic » Tue Jun 12, 2018 2:04 pm
It’s instaled. This is the only distro this has happened on
Post by fehlix » Tue Jun 12, 2018 2:49 pm
Welcome to the forum.
Please do show us the output of this command from the command line:
inxi -FNzx
Put the output within [code][/ code] tags
by pressing the code-tag icon above the editor-window </>
and paste between the code tags [code] paste the output here [/code] .
Thanks
cmscritic
Post by cmscritic » Tue Jun 12, 2018 5:40 pm
As requested.
System:    Host: critical Kernel: 4.15.0-1-amd64 x86_64 bits: 64 compiler: gcc v: 6.3.0 Desktop: Xfce 4.12.3
           tk: Gtk 2.24.31 Distro: MX-17.1_x64 Horizon March 14, 2018
Machine:   Type: Laptop System: Acer product: Nitro AN515-51 v: V1.13 serial: <filter>
           Mobo: KBL model: Freed_KLS v: V1.13 serial: <filter> UEFI: Insyde v: 1.13 date: 12/26/2017
Battery:   ID-1: BAT1 charge: 47.6 Wh condition: 47.6/48.9 Wh (97%) model: COMPAL PABAS0241231 status: Full
CPU:       Topology: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Skylake rev: 9
           L2 cache: 6144 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44928
           Speed: 1601 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 1600 2: 1600 3: 1505 4: 1600 5: 1600
           6: 1600 7: 1533 8: 1600
Graphics:  Card-1: Intel driver: i915 v: kernel bus ID: 00:02.0
           Card-2: NVIDIA driver: N/A bus ID: 01:00.0
           resolution: 1920x1080~60Hz
           OpenGL: renderer: Mesa DRI Intel Kabylake GT2 v: 4.5 Mesa 13.0.6 direct render: Yes
Audio:     Card-1: Intel driver: snd_hda_intel v: kernel bus ID: 00:1f.3
Network:   Card-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter driver: ath10k_pci v: kernel
           bus ID: 02:00.0
           Card-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: 2.3LK-NAPI
           port: 3000 bus ID: 03:00.1
Drives:    HDD Total Size: 894.25 GiB used: 16.21 GiB (1.8%)
           ID-1: /dev/sda vendor: SanDisk model: Ultra II 960GB size: 894.25 GiB
Partition: ID-1: / size: 876.97 GiB used: 16.21 GiB (1.8%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 44.0 C mobo: 29.8 C
Info:      Processes: 234 Uptime: 10h 16m Memory: 7.68 GiB used: 938.9 MiB (11.9%) Init: SysVinit runlevel: 5
           Compilers: gcc: 6.3.0 Shell: bash v: 4.4.12 inxi: 3.0.10
Post by fehlix » Wed Jun 13, 2018 10:28 am
Which WiFi channels are used on MX Linux?
If radar is detected most channels in use are blocked for 10-30 minutes by DFS regulation.
... This is the only distro this has happened on
And which WiFi channels are used on those other distros?
Return to “MX Help”
