Lost wallpaper and right-click on desktop SOLVED
kevtardis
Post by kevtardis » Fri Jun 08, 2018 12:31 am
Recently installed MX 17.1 on a Dell Optiplex without any problem. This is the only OS on the PC. Everything has been working fine.
Today, after a reboot, the desktop background came up as solid gray instead of my maine-sunrise.jpg. If I right-click on the desktop, I don't get a menu. If I go to Setting Manager-> Desktop -> Background and select any background wallpaper, nothing happens. Everything else seems to be working as per normal.
Trying to diagnose the problem, I ran 'inxi -Fxz' and compared the results to the output from the same command run three weeks ago. The results were different.
For example, the old 'inxi' command run three weeks ago showed:
System: Host: MX Kernel: 4.15.0-1-amd64 x86_64 bits: 64 Desktop: Xfce 4.12.3
Distro: MX-17.1_x64 Horizon March 14, 2018
the 'inxi' command run today shows:
System: Host: MX Kernel: 4.15.0-1-amd64 x86_64 bits: 64 compiler: gcc v: 6.3.0 Desktop: N/A
Not sure what to make of it, but I'm concerned. Any thoughts would be welcome.
Re: Lost wallpaper and right-click on desktop
Post by asqwerth » Fri Jun 08, 2018 1:10 am
Please post the output of
inxi -r
kevtardis
Post by kevtardis » Fri Jun 08, 2018 1:51 am
kev@MX:~
$ inxi -r
1: deb http://repo.antixlinux.com/stretch stretch main
1: deb http://repo.vivaldi.com/stable/deb/ stable main
kev@MX:~
Post by asqwerth » Fri Jun 08, 2018 2:03 am
Hmm. Seems ok.
Please print the full system info output for
inxi -Fxz
that you mentioned doing.
Maine sunrise is the default background for MX16. At that time, the wallpapers were stored here: /usr/local/share/backgrounds/MX16 [and then the appropriate subfolder]
In MX17, the wallpapers are in /usr/share/backgrounds.
However, the fact that you no longer can get the desktop rightclick menu is worrying. So I don't thnk it's just a matter of the wallpapers having been moved elsewhere. Did you preserve /home partition from MX16 or another distro when you installed MX17.1?
I think someone more knowledgeable needs to continue from here.
There was this discussion here: viewtopic.php?f=121&t=38787&p=424139&hi ... .3#p424139
about gcc6.3.0 and the liquorix kernel.
So maybe it's some issue with your kernels and their video drivers?
rich
Post by rich » Fri Jun 08, 2018 2:09 am
Well I don't know what happened, but it looks like xfce is messed up somehow. If nothing else I can compare the packages on your system to the packages on a working system. If you can provide a list of your installed packages, I'll take a look - you could do:
dpkg -l > packagelog.txt
and provide packagelog.txt as an attachment
I could also take a look at your apt history and see if I can figure out what happened, if you wanted to you could provide a record of your recent apt history like
cat /var/log/apt/history.log > aptlog.txt
If your comfortable with sharing that.
And I loved it cuz
It was all about me.
kevtardis
Post by kevtardis » Fri Jun 08, 2018 3:46 pm
To Asqwerth's point, my wallpapers are in another folder. But Setting Manager-> Desktop -> Background is pointed to that folder, and was working fine up until yesterday. I also tried pointing it to /usr/share/backgrounds, and was unable to pull up any wallpapers from that folder either. I had actually modified maine-sunrise.jpg so that it reads 'MX Linux" instead of "MX16".
Rich, attached please find the two files you requested. I appreciate you taking the time to give them a look.
Thank you both for your help so far.
kevtardis
kevtardis
Post by kevtardis » Fri Jun 08, 2018 3:47 pm
Sorry, looks like the other attachment didn't make the previous post. Here it is...
Post by dolphin_oracle » Fri Jun 08, 2018 3:57 pm
sounds like xfdesktop crashed, or was otherwise shutdown before the session saved one exit.
so open Session & Startup and check to make sure xfdesktop is set to start.
also, use the Session & Startup tool to clear any saved sessions, logout, and login.
you can also run "xfdesktop &" from the terminal, which should start the desktop if its not running.
Last edited by dolphin_oracle on Fri Jun 08, 2018 3:59 pm, edited 2 times in total.
lenovo ThinkPad T530 - MX-18
kevtardis
Post by kevtardis » Fri Jun 08, 2018 7:13 pm
Appears that was exactly the problem.
I don't see xfdesktop in Session and Startup -> Application Autostart tab, but when I entered 'xfdesktop &' in terminal the wallpaper was restored and my right-click menu is back.
Can I just click on the 'add' button and add a new autostart item called xfdesktop (on the Application Autostart tab)? Or does it go by another name?
Thanks so much!
kevtardis
#10
Post by dolphin_oracle » Fri Jun 08, 2018 7:43 pm
Thanks so much!
kevtardis
actually it will probably restart on its own now.
Return to “MX Help”
