  • Mepis support still here
  • MX-16.1 release info here
  • antiX-17 release info here
    • Read Forum Rules
dist-upgrade of Broadcom 64-bit STA mode wl driver
TJ Hoye
#1 Postby TJ Hoye » Wed Feb 14, 2018 5:05 pm
I have recently done a dis-upgrade of the Broadcom 64-bit STA mode wl driver.
This upgrade including the initramfs operation to connect the driver with the 14.4 kernel was successful,
with wireless throughput apparently the same or better than it was previously.
The 6.30.223.271 nomenclature is the same Broadcom numerology as it has been for the last few years, or so.
What is different in new 'MX-17' version that made this dist-upgrade necessary?
TIA
64-bit MX-17 beta 3 Ultra Fit LiveUSB on dual-cpu Win7-era laptop,
continuously dist-upgraded, often remastered, & using 4.14 kernel.
Re: dist-upgrade of Broadcom 64-bit STA mode wl driver
#2 Postby dolphin_oracle » Wed Feb 14, 2018 5:18 pm
TJ Hoye wrote:I have recently done a dis-upgrade of the Broadcom 64-bit STA mode wl driver.
TIA
its patched so that the dkms modules (the driver) will build on the later kernels and the antiX 4.15 kernel.
eeepc 904ha antix 15 32 bit (streaming media player)
acer c720p chromebook - chromeos / MX15-64 (custom snapshot) live USB.
lenovo s21e - antiX-16 MX16(live-usb)
#3 Postby Stevo » Wed Feb 14, 2018 6:09 pm
Yes, since the antiX 4.15 kernel is showing up in the main repo, we decided to update the out-of-tree dkms drivers in main as necessary to build with the new kernel. Since the code in the patches only is used if the new kernel is detected, essentially you have exactly the same driver as before with the 4.14 kernel.
TJ Hoye
#4 Postby TJ Hoye » Wed Feb 14, 2018 11:48 pm
What is the current guidance on which kernel to use with MX-17?
#5 Postby asqwerth » Thu Feb 15, 2018 12:45 am
TJ Hoye wrote:What is the current guidance on which kernel to use with MX-17?
Look at the top of the forum main page for the Welcome box with links to news and announcements. You'll see a link in the line "Please read this important information about Spectre and Meltdown vulnerabilities."
Return to “MX Help”
Who is online
Users browsing this forum: No registered users and 7 guests
