-- Change in MX sources
-- antiX-17 release info here
[SOLVED] Touchpad not working on MX17, Acer Aspire ES 15
markos
#1 Post by markos » Tue Feb 13, 2018 9:03 pm
Hi all. Mouse is working fine but no touchpad. I installed the "Touchpad Indicator" but its menu does not come up. I click and nothing happens.
libinput is not installed on my laptop:
root@markos-laptop:~# libinput
-su: libinput: command not found
synclient and syndaemon not working:
root@markos-laptop:~# synclient
Couldn't find synaptics properties. No synaptics driver loaded?
root@markos-laptop:~# syndaemon
Unable to find a synaptics device.
No synaptics entry in Xorg.0.log:
markos@markos-laptop:~
$ cat /var/log/Xorg.0.log | grep syna
$ cat /var/log/Xorg.0.log | grep *touch*
No touchpad/synaptics in xinput:
$ xinput
 Virtual core pointer                    	id=2	[master pointer  (3)]
   Virtual core XTEST pointer              	id=4	[slave  pointer  (2)]
   Logitech Logitech Extreme 3D            	id=11	[slave  pointer  (2)]
   Logitech USB Optical Mouse              	id=12	[slave  pointer  (2)]
 Virtual core keyboard                   	id=3	[master keyboard (2)]
    Virtual core XTEST keyboard             	id=5	[slave  keyboard (3)]
    Power Button                            	id=6	[slave  keyboard (3)]
    Video Bus                               	id=7	[slave  keyboard (3)]
    Power Button                            	id=8	[slave  keyboard (3)]
    Sleep Button                            	id=9	[slave  keyboard (3)]
    Logitech Logitech Extreme 3D (keys)     	id=10	[slave  keyboard (3)]
    VGA Webcam: VGA Webcam                  	id=13	[slave  keyboard (3)]
    AT Translated Set 2 keyboard            	id=14	[slave  keyboard (3)]
    Acer WMI hotkeys                        	id=15	[slave  keyboard (3)]
    ACPI Virtual Keyboard Device            	id=16	[slave  keyboard (3)]
10-evdev.conf:
root@markos-laptop:~# cat /etc/X11/xorg.conf.d/10-evdev.conf
# Catch-all evdev loader for udev-based systems
# We don't simply match on any device since that also adds accelerometers
# and other devices that we don't really want to use. The list below
# matches everything but joysticks.
Section "InputClass"
        Identifier "evdev pointer catchall"
        MatchIsPointer "on"
        MatchDevicePath "/dev/input/event*"
        Driver "evdev"
EndSection
        Identifier "evdev keyboard catchall"
        MatchIsKeyboard "on"
        Driver "evdev"
EndSection
        Identifier "evdev touchpad catchall"
        MatchIsTouchpad "on"
        Driver "evdev"
EndSection
        Identifier "evdev tablet catchall"
        MatchIsTablet "on"
        Driver "evdev"
EndSection
        Identifier "evdev touchscreen catchall"
        MatchIsTouchscreen "on"
        Driver "evdev"
EndSection
synaptics.conf:
root@markos-laptop:~# cat /etc/X11/xorg.conf.d/synaptics.conf
        Identifier      "touchpad catchall"             # required
        MatchIsTouchpad "on"                            # required
        Driver          "synaptics"                     # required
        Option          "MinSpeed"              "0.5"
        Option          "MaxSpeed"              "1.0"
        Option          "AccelFactor"           "0.075"
        Option          "TapButton1"            "1"
        Option          "TapButton2"            "2"     # multitouch
        Option          "TapButton3"            "3"     # multitouch
        Option          "VertTwoFingerScroll"   "1"     # multitouch
        Option          "HorizTwoFingerScroll"  "1"     # multitouch
        Option          "VertEdgeScroll"        "1"
        Option          "HorizEdgeScroll" "1"
        Option          "CoastingSpeed"         "8"
        Option          "CornerCoasting"        "1"
        Option          "CircularScrolling"     "1"
        Option          "CircScrollTrigger"     "7"
        Option          "EdgeMotionUseAlways"   "1"
        Option          "LBCornerButton"        "8"     # browser "back" btn
        Option          "RBCornerButton"        "9"     # browser "forward" btn
70-synaptics.conf:
root@markos-laptop:~# cat /usr/share/X11/xorg.conf.d/70-synaptics.conf
# Example xorg.conf.d snippet that assigns the touchpad driver
# to all touchpads. See xorg.conf.d(5) for more information on
# InputClass.
# DO NOT EDIT THIS FILE, your distribution will likely overwrite
# it when updating. Copy (and rename) this file into
# /etc/X11/xorg.conf.d first.
# Additional options may be added in the form of
#   Option "OptionName" "value"
        Driver "synaptics"
# This option is recommend on all Linux systems using evdev, but cannot be
# enabled by default. See the following link for details:
# http://who-t.blogspot.com/2010/11/how-to-ignore-configuration-errors.html
#       MatchDevicePath "/dev/input/event*"
EndSection
        Identifier "touchpad ignore duplicates"
        MatchOS "Linux"
        MatchDevicePath "/dev/input/mouse*"
        Option "Ignore" "on"
EndSection
# This option enables the bottom right corner to be a right button on clickpads
# and the right and middle top areas to be right / middle buttons on clickpads
# with a top button area.
# This option is only interpreted by clickpads.
        Identifier "Default clickpad buttons"
        MatchDriver "synaptics"
        Option "SoftButtonAreas" "50% 0 82% 0 0 0 0 0"
        Option "SecondarySoftButtonAreas" "58% 0 0 15% 42% 58% 0 15%"
EndSection
# This option disables software buttons on Apple touchpads.
        Identifier "Disable clickpad buttons on Apple touchpads"
        MatchProduct "Apple|bcm5974"
        Option "SoftButtonAreas" "0 0 0 0 0 0 0 0"
EndSection
Re: Touchpad not working on MX17, Acer Aspire ES 15
#2 Post by dolphin_oracle » Tue Feb 13, 2018 10:03 pm
I have seen some info that setting the touch to "basic" in bios will allow the touchpad to work. Other sources state that installing i2c-tools will allow the touchpad to work as well after reboot.
there are a lot of ubuntu users with threads about that the espire e15 laptops and their touchpads.
lenovo ThinkPad T530 - MX-17
markos
#3 Post by markos » Wed Feb 14, 2018 1:10 pm
dolphin_oracle wrote:I have seen some info that setting the touch to "basic" in bios will allow the touchpad to work. Other sources state that installing i2c-tools will allow the touchpad to work as well after reboot.
I switched from "Advanced" to "Basic" but no avail. I installed i2c-tools but don't know how to use it. I read the man page and it seems you have to supply a hardware device ID to the tool so it can probe the device (touchpad). The touchpad is not recognized by MX so there's no device ID for it. Anyway, thanks for your help. I will defer this for later.
rokytnji.1
#4 Post by rokytnji.1 » Wed Feb 14, 2018 3:00 pm
Maybe
dmesg | tail
might shed some light. Or not. Maybe a alternate kernel install is called for. I had a usb 3.0 express card I had to change the kernel on
for AntiX to see it. I went from 4.14 to 4.9.
markos
#5 Post by markos » Wed Feb 14, 2018 6:04 pm
rokytnji.1 wrote:Maybe
dmesg | tail
dmesg contains no output for touchpad but it does for mouse. Before your post I checked syslog but didn't find much. After I read your post I googled and did a bit of reading on kernel log files and run the following:
grep -i synaptics /var/log/*
Finally, I got some hits:
/var/log/kern.log:Feb 14 23:39:58 markos-laptop kernel: [    2.864960] psmouse serio1: elantech: Synaptics capabilities query result 0x00, 0x15, 0x0f.
/var/log/kern.log:Feb 14 23:39:58 markos-laptop kernel: [    2.875463] psmouse serio1: elantech: Elan sample query result 0b, 38, 75
/var/log/kern.log:Feb 14 23:39:58 markos-laptop kernel: [    2.931168] input: ETPS/2 Elantech Touchpad as /devices/platform/i8042/serio1/input/input2
And the exact same entries were repeated at
/var/log/messages
/var/log/syslog
i8042 appears in the grep output above as a directory. I remembered I saw a youtube vid that used that value to fix a "touchpad not working" issue. So I googled some more on i8042 and found this article (https://askubuntu.com/questions/525629/ ... recognized), followed the instructions and it worked. I spent a whole day to get the touchpad to work on linux. LOL
Re: [SOLVED] Touchpad not working on MX17, Acer Aspire ES 15
#6 Post by Jerry3904 » Wed Feb 14, 2018 6:23 pm
Impressive--good work!
Return to “MX Help”
