-- Change in MX sources
-- antiX-17 release info here
[noob question] Does MX-17 install the latest amd/ati drivers automatically?
14u2ponder
#1 Post by 14u2ponder » Tue Feb 13, 2018 2:44 pm
I am struggling to understand the video card install process. Mainly my problem is just not understanding the install process. I do have some screen tearing and I followed one of the threads that told me to add this to my startup:
compton --backend glx --paint-on-overlay --vsync opengl-swc
I read that installing the driver requires to install it on the kernel and the X environment.
Also, there any packages that help with graphic cards performance that I could add to my system. Any help is appreciated.
My setup:
$ inxi -G
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Baffin [Radeon RX 460]
           Display Server: x11 (X.Org 1.19.2 )
           drivers: ati,amdgpu (unloaded: modesetting,fbdev,vesa,radeon)
           Resolution: 2560x1440@59.95hz
           OpenGL: renderer: Gallium 0.4 on AMD POLARIS11 (DRM 3.18.0 / 4.13.0-1-amd64, LLVM 3.9.1)
           version: 4.3 Mesa 13.0.6
14u2ponder
Re: [noob question] Does MX-17 install the latest amd/ati drivers automatically?
#2 Post by 14u2ponder » Tue Feb 13, 2018 3:05 pm
I found a command to look at my kernel and here's what's on it:
dpkg --list | grep linux-image
ii  linux-image-4.13.0-1-amd64            4.13.13-1mx17                     amd64        Linux 4.13 for 64-bit PCs
So it appears that I might have the latest drivers. From my previous reading it seems like I COULD add these: modesetting,fbdev,vesa,radeon, but that I am using amdgpu. Is that right?
#3 Post by timkb4cq » Tue Feb 13, 2018 3:24 pm
Yes, you are running the AMDGPU driver, which is the correct one for your video hardware. The old fglrx proprietary drivers are not supported by current kernels & Xorg so they are no longer an option. Since AMD open sourced AMDGPU, MX can use it automatically.
Others here have eliminated screen tearing using the AMDGPU driver by creating a file "20-amdgpu.conf" in /etc/X11/xorg.conf.d with the following content:
Section "Device"
Identifier "Card0"
Driver "amdgpu"
BusID "PCI:1:0:0"
Option "TearFree" "on"
EndSection
A restart of the X server is required for this to take effect (easiest way is to reboot).
#4 Post by Stevo » Tue Feb 13, 2018 3:53 pm
I've been doing some work to upgrade the open video driver stack for the test repo, but so far only the necessary compilers (llvm-5.0 toolchain) has made it into the test repo. I've gotten up to a Mesa backport from testing in an OBS repo, though.
14u2ponder
#5 Post by 14u2ponder » Tue Feb 13, 2018 9:20 pm
I have one other question and don't want to start another thread. I am trying to map my mouse buttons. I installed xbindkeys and tried to configure the file but nothing seems to work. I know that xbindkeys daemon is running (I checked it), so I'm thinking I either have to include the file in my $PATH or put the configuration file in a config folder or something. Currently, it is located in user/home folder.
Can somebody help?
#6 Post by Jerry3904 » Tue Feb 13, 2018 9:38 pm
>> new thread, please
Return to “MX Help”
