[SOLVED]failure with desktop-defaults-xfce-mx17
penguin
Post by penguin » Sat Feb 10, 2018 5:33 pm
Today have problem during update of my MX 17 /32 bit. Failure with desktop-defaults-xfce-mx17
when I trying to repair
sudo apt-get -f install
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  libaribb24-0 libmicrodns0 libopencv-contrib2.4v5 libopencv-ml2.4v5 libplacebo2
  libqt5multimediawidgets5 libva-wayland1 libvlccore9 libvulkan1
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up desktop-defaults-xfce-mx17 (0.7.17.4.7) ...
dpkg: error processing package desktop-defaults-xfce-mx17 (--configure):
 subprocess installed post-installation script returned error exit status 1
E: Sub-process /usr/bin/dpkg returned an error code (1)
I removed and tried to install it as follow:
sudo aptitude install desktop-defaults-xfce-mx17:i386
The following NEW packages will be installed:
The following packages will be REMOVED:
  libaribb24-0{u} libmicrodns0{u} libopencv-contrib2.4v5{u} libopencv-ml2.4v5{u} libplacebo2{u}
  libqt5multimediawidgets5{u} libva-wayland1{u} libvlccore9{u} libvulkan1{u}
0 packages upgraded, 1 newly installed, 9 to remove and 0 not upgraded.
Need to get 0 B/58.5 kB of archives. After unpacking 3,537 kB will be freed.
Do you want to continue? [Y/n/?] y
(Reading database ... 403716 files and directories currently installed.)
Removing libaribb24-0:i386 (1.0.3-1~mx17+1) ...
Removing libmicrodns0:i386 (0.0.3-3) ...
Removing libopencv-contrib2.4v5:i386 (2.4.9.1+dfsg1-2) ...
Removing libopencv-ml2.4v5:i386 (2.4.9.1+dfsg1-2) ...
Removing libplacebo2:i386 (0.2.0-2~mx17+1) ...
Removing libqt5multimediawidgets5:i386 (5.7.1~20161021-2) ...
Removing libva-wayland1:i386 (1.7.3-2) ...
Removing libvlccore9:i386 (3.0.0-1~mx17+1) ...
Removing libvulkan1:i386 (1.0.65.2+dfsg1-1~mx17+1) ...
(Reading database ... 403666 files and directories currently installed.)
Preparing to unpack .../desktop-defaults-xfce-mx17_0.7.17.4.7_all.deb ...
Unpacking desktop-defaults-xfce-mx17 (0.7.17.4.7) ...
Processing triggers for mime-support (3.60) ...
Processing triggers for desktop-file-utils (0.23-1) ...
Processing triggers for libc-bin (2.24-11+deb9u1) ...
Processing triggers for systemd (232-25+deb9u1) ...
Processing triggers for gnome-menus (3.13.3-9) ...
[b]Errors were encountered while processing:
 desktop-defaults-xfce-mx17[/b]
Problem persists.
Re: failure with desktop-defaults-xfce-mx17
Post by Stevo » Sat Feb 10, 2018 6:01 pm
Please post the output of this command:
cat /etc/apt/sources.list.d/debian.list
Since the postinst script is trying to modify that file.
penguin
Post by penguin » Sat Feb 10, 2018 6:44 pm
# Debian Stable.
deb http://ftp.us.debian.org/debian/ stretch main contrib non-free
deb http://security.debian.org/ stretch/updates main contrib non-free
# deb-src http://ftp.us.debian.org/debian/ stretch main contrib non-free
#stretch backports
# deb http://deb.debian.org/debian/ stretch-backports main
Because this package is Optional, I removed it.But I don't know if it is solution or not.
Post by dolphin_oracle » Sat Feb 10, 2018 7:17 pm
are you running Xfce?
does /etc/skel/.config/Thunar/ exist?
does /root/.config/Thunar/ exist?
lenovo ThinkPad T530 - MX-18
penguin
Post by penguin » Sat Feb 10, 2018 7:27 pm
dolphin_oracle wrote:are you running Xfce?
 /etc/skel/.config/Thunar/ - Yes
 /root/.config/Thunar/      - No
In the second one only Pulse directory exists.But as see from desktop-defaults-xfce-mx17 deb, this package wants to write a lot values to
/root/.config/autostart/
/root/.config/clipit/
etc.
Post by dolphin_oracle » Sat Feb 10, 2018 7:44 pm
would you mind trying to install the version attached?
penguin
Post by penguin » Sat Feb 10, 2018 7:56 pm
dolphin_oracle wrote:would you mind trying to install the version attached?
Installed the previous version and installed the new one. But when open Synaptic I found that desktop-defaults-xfce-mx17 is installed.
Post by dolphin_oracle » Sat Feb 10, 2018 8:13 pm
could you try removing desktop-defaults-xfce-mx17 then only installing the version I attached.
penguin
Post by penguin » Sat Feb 10, 2018 8:19 pm
dolphin_oracle wrote:could you try removing desktop-defaults-xfce-mx17 then only installing the version I attached.
Maybe I did not explained correctly , but I did. I installed previous and installed the new one. Output as per photo attached on the previous post.
#10
Post by dolphin_oracle » Sat Feb 10, 2018 9:02 pm
ok, I can't duplicate this on a 64 bit system...I'm going to set up a 32 bit system and see what happens.
Return to “MX Help”
