MX-17 won't boot up anymore. [solved]
Mauser
Post by Mauser » Wed Feb 07, 2018 11:27 pm
I have done several boot ups today and everyting was fine. I left my desktop on while watching the original Star Trek episode on my TV. Afterwards I went to watch a YouTube video on my desktop and there was no sound. I clicked on the sound icon in the panel and the mixer was gone. Then I went into settings and it was completely blank. No settings for anything in there. Just an empty control panel. I rebooted the computer and it won't boot. It will show grub then the long list of texts as usual, and then I get a blank black screen with a blinking white horizontal curser. How do I fix this?
I am command line illiterate. :confused:
stsoh
Re: MX-17 won't boot up anymore.
Post by stsoh » Thu Feb 08, 2018 1:11 am
can it be the usb-stick fault? nowadays usb-memory stick isn't very reliable, try a different usb-memory stick.
never buy any usb-memory stick more than 32gb, reason they r compressed-data on 32gb.
i brought two 64gb usb-memory sticks, new 64gb usb-stick dead in less than a month.
do a chip scan n found to be 32gb, the other gone in less than a year.
never buy any cheap usb-memory stick from china.
original from yesteryears r still run w/o problem. new ones, failed one after another.
azrielle
Post by azrielle » Thu Feb 08, 2018 2:00 am
USB-3sticks from REPUTABLE manufacturers greater than 32GB are just fine. I have 8 Sandisk 256GB sticks, 1 Kingston 256GB stick that have been running in a hub connected to a Vizio smart tv for about a year. Other brands that are reliable are Samsung and Mushkin.
Lenovo T430 i5/3320m 8GB 14.1" MX17.1/Win7SP1 180GB SSD/128GB mSATA
Lenovo X230 i7/3520m 12GB 12.5" MX17.1/AntiX 17.1 Fluxbox/Win7SP1 500GB SSD
Lenovo X131e i3/3227u 8GB 11.6" MX17.1/AntiX 17.1 Fluxbox/Win7SP1 500GB SSD
stsoh
Post by stsoh » Thu Feb 08, 2018 2:51 am
both 64gb r Toshiba, made in Philippines....pieces of crap. :mad:
now my 32gb sandisk otg usb3.0 acting problems. :mad:
add note:
got two 64gb usb-stick from china, only can store up to 16gb, storage shows 64gb on file manager. more crap. :mad:
Post by Adrian » Thu Feb 08, 2018 9:45 am
It could be something else, from what I understand it actually boots (the scrolling text) but you don't get a useful screen, that could be related to video card driver. What do you use what card do you have can you boot from a stick and post inxi -F.
Mauser
Post by Mauser » Thu Feb 08, 2018 10:00 am
No no no no. I am not booting from a usb. It's booting from the hhd that it booted fine before for months. I have no stick to boot from. I can't post system information because it won't boot. I see grub fine then all that text info as usual, then it goes black with a blinking white curser on the top left corner. Help.
Post by Adrian » Thu Feb 08, 2018 10:35 am
You don't have any flashdrive to boot from and post the info or it doesn't boot from a flashdrive either? You could also tell us what video card you have and what driver you use if you know (like: "I remember I installed Nvidia proprietary driver") it's really not much info to troubleshoot/fix things remotely if you don't give us the basic info.
If you boot from flashdrive you might also be able to examine logs to see what and where goes wrong see what updates you installed lately (in case those caused this issue).
chrispop99
Post by chrispop99 » Thu Feb 08, 2018 10:37 am
What happens if you press Ctrl-Alt-F1 at that screen?
Test machines:
Mauser
Post by Mauser » Thu Feb 08, 2018 10:56 am
chrispop99 wrote:What happens if you press Ctrl-Alt-F1 at that screen?
OK. New keyboard working fine. I get cli installer. My correct password doesn't work though.
Mauser
#10
Post by Mauser » Thu Feb 08, 2018 11:05 am
I posted a reply earlier but it disappeared. My keyboard was typing incorrectly. There a notification fromJerry that it was closed but it won't let me view it. My computer can't fully boot up.
Return to “MX Help”
