New users[/u
SOLVED -- How to fix freezing.
rdotex
Post by rdotex » Wed Jan 17, 2018 4:47 pm
I'm using MX-16.1 and am now getting the freezing of the display. Never got that on MX-15 or any earlier. How to solve? I will reinstall an older version if needed to fix this!
Edit: Actually, the display is not freezing, it seems to be Firefox. The cursor still moves, and the 'ctrl, alt esc' gives the 'kill sign', but is slow to act.
inxi -F
$ inxi -F
System: Host: mx1 Kernel: 4.7.0-0.bpo.1-amd64 x86_64 bits: 64 Desktop: Xfce 4.12.2
Distro: MX-16_x64 Metamorphosis 12 December 2016
Machine: Device: desktop System: Dell product: OptiPlex 755 serial: N/A
Mobo: Dell model: 0GM819 serial: N/A BIOS: Dell v: A04 date: 11/05/2007
CPU: Dual core Intel Core2 Duo E4400 (-MCP-) cache: 2048 KB
clock speeds: max: 1995 MHz 1: 1995 MHz 2: 1995 MHz
Graphics: Card: Intel 82Q35 Express Integrated Graphics Controller
Display Server: X.Org 1.16.4 drivers: intel (unloaded: modesetting,fbdev,vesa)
Resolution: 1280x1024@60.02hz
OpenGL: renderer: Mesa DRI Intel Q35 version: 2.1 Mesa 12.0.3
Audio: Card Intel 82801I (ICH9 Family) HD Audio Controller driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.7.0-0.bpo.1-amd64
Network: Card: Intel 82566DM-2 Gigabit Network Connection driver: e1000e
IF: eth0 state: up speed: 10 Mbps duplex: half mac: 00:1e:4f:93:89:d0
Drives: HDD Total Size: 580.1GB (1.6% used)
ID-1: /dev/sdb model: ST3500630AS size: 500.1GB
ID-2: /dev/sda model: WDC_WD800JD size: 80.0GB
Partition: ID-1: / size: 72G used: 6.9G (11%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 2.18GB used: 0.19GB (9%) fs: swap dev: /dev/sda2
Sensors: System Temperatures: cpu: 40.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 185 Uptime: 5:25 Memory: 390.9/1960.5MB Client: Shell (bash) inxi: 2.3.54
inxi-F
i_ri
Re: How to fix freezing.
Post by i_ri » Wed Jan 17, 2018 7:55 pm
hello rdotex
Is the apt-notifier showng any number of available upgrades?
Suggesting have machine complete a update, upgrade, shutdown, start. begin troubleshoooting after that.
Post by timkb4cq » Wed Jan 17, 2018 8:08 pm
If you installed saving home, it's likely you need to re-make Firefox's profile. Export your bookmarks, close Firefox and delete the hidden ~./mozilla folder. It will created fresh when you next start Firefox.
rdotex
Post by rdotex » Thu Jan 18, 2018 7:03 pm
i_ri wrote:hello rdotex
No. No updates showing. I do that almost daily.
rdotex
Post by rdotex » Thu Jan 18, 2018 7:05 pm
timkb4cq wrote:If you installed saving home, it's likely you need to re-make Firefox's profile. Export your bookmarks, close Firefox and delete the hidden ~./mozilla folder. It will created fresh when you next start Firefox.
I'm not really sure I understand all you said, but I will do the 'Export...' thing and let you know how it went.
rdotex
Post by rdotex » Fri Jan 19, 2018 2:25 pm
Well..., this 'Old Fart' cannot find "...the hidden -./mozilla folder"! Can you please tell me where it might be?j AND , how to find it!
Post by timkb4cq » Fri Jan 19, 2018 6:30 pm
In the File Manager, use the View menu to select Show Hidden Files. It's also toggleable with <Ctrl>+H
rdotex
Post by rdotex » Thu Jan 25, 2018 9:15 am
timkb4cq wrote:In the File Manager, use the View menu to select Show Hidden Files. It's also toggleable with <Ctrl>+H
OK. I finally got around to doing it and it Worked!
Thanks all!
How do I mark it as 'Solved'?
Kestrel
Post by Kestrel » Thu Jan 25, 2018 11:48 am
Go to your first post in the thread, click the edit button ie the one with the pencil icon and add the word "solved" in the title . Then click submit.
Dell Inspiron 530 Desktop
160gb HDD
8gb DDR2 RAM @ 800mhz
Intel® Core™2 Duo Processor E8600 (6M Cache, 3.33 GHz, 1333 MHz FSB)
Integrated Intel Graphics (no GPU installed)
MX-16.1 64-bit (4.9.0 kernel)
Return to “MX Help”
