disable caps lock key
penguin48
Post by penguin48 » Mon Jan 15, 2018 5:50 pm
Hello to all. This is my first post and I have spent several days looking for the answer to this. The question is seemingly a simple one, How do you disable the caps lock key in MX 17? I am not a total newbie and have run more than a dozen linux distros since my first one, Mint 15. In the distros I have used (this is my first xfce de), I have been able to go to system settings>keyboard>layout>options (or similar track) and check disable caps lock key. Not with MX 17. Maybe I'm missing something, but I have chased this around in circles so I am asking for some help here. Thanks in advance.
This is a new Lenovo Flex 5 1470. 256GB m2 ssd, second WD 250 GB sata III ssd with MX 17, (untouched windows factory install on the m2), 8B ram. intel i5 generation 7.
This is areal annoyance as other than this, MX 17 is a distro I will use. I like it a lot, but for now I am blind. Caps lock drives me nuts... :happy:
kmathern
Re: disable caps lock key
Post by kmathern » Mon Jan 15, 2018 6:03 pm
Read this thread: viewtopic.php?f=93&t=37161, it's from a couple years ago but I think it still works.
Post by Jerry3904 » Mon Jan 15, 2018 6:08 pm
Check this thread on the Xfce Forum:
https://forum.xfce.org/viewtopic.php?id=9615
penguin48
Post by penguin48 » Mon Jan 15, 2018 6:56 pm
OK thank you. However the first one from kmathern does not work. Too bad because it seems wicked simple too. I had found the second post by Jerry3904, but when I create the stated folder, it will not open with a text editor. Just open, or open in new window, neither of which let you enter the command. That site won't open now, so I'll go back later. Thanks again guys!
Is there some reason I can't see that xfce seems to be the only distro where you can't get into the keyboard through the settings manager and disable the caps lock? Seems if others can accomplish that why not here? Just seems strange.
kmathern
Post by kmathern » Mon Jan 15, 2018 7:15 pm
penguin48 wrote:OK thank you. However the first one from kmathern does not work. Too bad because it seems wicked simple too.
That's strange, it works for me.
I said earlier "I think it still works" because I hadn't actually tried it yet with MX-17, but I just booted into a MX-17 live-session to try it and it works (also works with MX-16).
If you followed the directions in the thread I linked to you should end up with a .desktop file (I named mine "disable_caplocks") in ~/.config/autostart something like what's shown below
$ cat ~/.config/autostart/disable_caplocks.desktop
[Desktop Entry]
Encoding=UTF-8
Version=0.9.4
Type=Application
Name=disable_caplocks
Comment=disable the capslock key
Exec=setxkbmap -option caps:none
OnlyShowIn=XFCE;
StartupNotify=false
Terminal=false
Hidden=false
Paul..
Post by Paul.. » Mon Jan 15, 2018 11:18 pm
If you can live with a Caps Lock and Num Lock indicator, there is a good one in the repo...very small and it works...I just installed for my 84 year old brother in law...he has an Asus laptop and has a keyboard with no LED indicator.
indicator-keylock
The indicator is in the Notification Area...and also pops up briefly when you hit the Caps Lock key as a notification in upper right of screen.
Asus Prime X470-Pro | AMD Ryzen 5 1400 (8 threads)
16 Gig DDR4 3000 | nVidia - GeForce GTX 750 Ti
Samsung 970 NVMe SSD | 860 500GB SSD
chrispop99
Post by chrispop99 » Tue Jan 16, 2018 5:01 am
Another option might be to assign a sound to it.
In Settings-Keyboard-Application Shortcuts, click Add. Enter the following:
mplayer /usr/share/sounds/Borealis/stereo/Kopete_status.ogg
then click OK. Press the Caps Lock key. You will now get a sound whenever you lock/unlock caps. You can change the sound file in the path to whatever you like; there is quite a selection in that folder.
Caveat: your sound system has to be on, with the volume at a suitable level.
Test machines:
penguin48
Post by penguin48 » Tue Jan 16, 2018 1:46 pm
OK, thanks a lot. issue seems resolved :happy:
Post by Jerry3904 » Tue Jan 16, 2018 3:14 pm
Please return to your first post and add "Solved" to the Subject line--thanks.
Return to “MX Help”
