-- Change in MX sources
-- antiX-17 release info here
Remote Login
Be OK
Remote Login
#1 Post by Be OK » Wed Jan 10, 2018 10:07 am
Hi, i have a machine with a troubled drive so i boot using the dvd as live session, works great.
Now i want to use my main computer (mx17) to login on the live machine.
What is the best way to do this ?
And is there a way to adapt the live dvd or usb to do that at every boot,like a repair dvd ?
whell
Re: Remote Login
#2 Post by whell » Wed Jan 10, 2018 10:42 am
In answer to your first question, I can recommend Remmina, which is in the MX-16 / 17 repo. Easy to set up and use.
I'll defer on your 2nd question to folks who use persistence USB tools.
Be OK
Re: Remote Login
#3 Post by Be OK » Wed Jan 10, 2018 1:09 pm
Ok remmina is in mx16 not in the mx17 repo had to use the backport repo.
That give a additional question how to get this on dvd-usb to run at live use.
Or some documents to read on this.
Pff looks like you need to set up ssh to :( And that for on a local network.
whell
Re: Remote Login
#4 Post by whell » Wed Jan 10, 2018 2:43 pm
Be OK wrote:Ok remmina is in mx16 not in the mx17 repo had to use the backport repo.
I don't use ssh on either my MX 16 or MX 17 box and connect easily my home network using Remmina. I think there were Remmina plugins that I needed to install to use Remmina the way I needed it.
Return to “MX Help”
