-- Change in MX sources
-- antiX-17 release info here
[Fixed] 4.14.12 kernel + nvidia driver
dr-kart
#1 Post by dr-kart » Mon Jan 08, 2018 8:00 am
moved to
4.14.0-3-amd64 #1 SMP Debian 4.14.12-2~mx17+1 (2018-01-06)
but failed to install nvidia video drivers via ddm-mx then (both main 375 and newer 384 backported one)
So I did
ddm-mx -p nvidia
then tried
ddm-mx -i nvidia
no joy.
Re: 4.14.12 kernel + nvidia driver
#2 Post by dolphin_oracle » Mon Jan 08, 2018 8:53 am
install
libelf-dev
and try ddm-mx again.
we are still working on update strategies for the 4.14.12 kernel. we uncovered that depend issue last nite.
lenovo ThinkPad T530 - MX-17
dr-kart
#3 Post by dr-kart » Mon Jan 08, 2018 12:05 pm
installed libelf-dev and libelf-dev:386 as well
ddm-mx logs:
1. As for 384 backported
DKMS: install completed.
Setting up nvidia-legacy-304xx-driver (304.137-3~bpo9+1) ...
Processing triggers for nvidia-alternative:i386 (384.98-3~bpo9+1) ...
update-alternatives: warning: forcing reinstallation of alternative /usr/lib/nvidia/current because link group nvidia is broken
Setting up nvidia-kernel-dkms (384.98-3~bpo9+1) ...
Loading new nvidia-current-384.98 DKMS files...
Building for 4.14.0-3-amd64
Building initial module for 4.14.0-3-amd64
Error! Bad return status for module build on kernel: 4.14.0-3-amd64 (x86_64)
Consult /var/lib/dkms/nvidia-current/384.98/build/make.log for more information.
Setting up nvidia-driver (384.98-3~bpo9+1) ...
Processing triggers for libc-bin (2.24-11+deb9u1) ...
Processing triggers for glx-alternative-nvidia:i386 (0.7.4) ...
Processing triggers for menu (2.1.47+b1) ...
Processing triggers for update-glx (0.7.4) ...
update-alternatives: using /usr/lib/nvidia to provide /usr/lib/glx (glx) in auto mode
Processing triggers for initramfs-tools (0.130) ...
update-initramfs: Generating /boot/initrd.img-4.14.0-3-amd64
New X configuration file written to '/etc/X11/xorg.conf'
Finished
but I have black screen at the end (same as before with no libelf-dev installed)
2. Main 375 even worse now.
Preparing to unpack .../build-essential_12.3_amd64.deb ...
Unpacking build-essential (12.3) over (12.3) ...
Preparing to unpack .../firmware-linux-nonfree_20170823-1mx17+1_all.deb ...
Unpacking firmware-linux-nonfree (20170823-1mx17+1) over (20170823-1mx17+1) ...
Preparing to unpack .../linux-headers-4.14.0-3-amd64_4.14.12-2~mx17+1_amd64.deb ...
Unpacking linux-headers-4.14.0-3-amd64 (4.14.12-2~mx17+1) over (4.14.12-2~mx17+1) ...
Setting up build-essential (12.3) ...
Setting up linux-headers-4.14.0-3-amd64 (4.14.12-2~mx17+1) ...
Setting up firmware-linux-nonfree (20170823-1mx17+1) ...
Reading package lists...
Building dependency tree...
Reading state information...
 libgl1-nvidia-glx:i386 : Depends: libnvidia-glcore:i386 (= 375.82-9mx17+1) but it is not going to be installed
Finished
I notice couple 'FATAL ERROR' messages during boot process saying something about nvidia module. This msg comes out every time I boot with nvidia proprietary drivers. What log file should I look at?
#4 Post by dolphin_oracle » Mon Jan 08, 2018 1:07 pm
for the 384 backport version, I would try removing /etc/X11/xorg.conf and rebooting to see if the driver picks up.
dr-kart
#5 Post by dr-kart » Mon Jan 08, 2018 1:34 pm
didn't help.
But I made "screenshot"
its DRM module error
#6 Post by dolphin_oracle » Mon Jan 08, 2018 1:37 pm
didn't help.
shoot, I missed that, sorry.
reported up the line to the repo guys.
#7 Post by timkb4cq » Mon Jan 08, 2018 2:30 pm
You shouldn't need to install any i386 libraries to install nvidia drivers on a 64bit system.
Your best bet for clearing up the mess is to use sgfxi to install the nvidia driver for now. Just <Ctl><Alt><F1> into a console terminal, log in as root and run
sgfxi
Just follow the prompts.
It will remove ddm-mx in the process, but that can be reinstalled later if you wish to use it to switch to a different driver.
Eadwine Rose
#8 Post by Eadwine Rose » Mon Jan 08, 2018 2:33 pm
Just make sure you run sgfxi TWICE. Complete one, then repeat.
MX-17.1_x64 Horizon 14-3-2018 * 4.15.0-1-amd64 ext4 Xfce 4.12.3 * AMD Asus M4A785TD-V EVO AM3 * ASUS GF GT640-1GD5-L NVIDIA 384.111 * AMD Proc. Athl II X4 635, sAM3 * HDA ATI SB VT1708S An * 2x4Gb DDR3 1600 Kingst * 22" Samsung SyncM P2250 * HP F2280
#9 Post by timkb4cq » Mon Jan 08, 2018 2:43 pm
It looks as though you have different versions of i386 & amd64 libraries fighting with each other. I don't think ddm-mx allows for the possibility that you have installed both i386 & amd64 versions of the nvidia drivers on the same install. That's definitely an unusual corner case.
#10 Post by Stevo » Mon Jan 08, 2018 3:21 pm
ddm-mx installs some of the 32-bit Nvidia libraries on a 64-bit system in order to support Steam or Wine games, such as the openGL one, but versions have to match exactly. The mismatch probably where the problem lies.
Return to “MX Help”
