  • Mepis support still here
  • MX-17.1 Final release info here
  • antiX-17 release info here
  • Read Forum Rules
Additional Drivers not working [SOLVED]
davejones
#1 Postby davejones » Sun Jan 07, 2018 6:13 pm
It won't start from the menu or application finder. Whenever I run software-properties-gtk as root or a regular user, I get the following error:
user$ software-properties-gtk --massive-debug
ERROR:root:Cannot import UbuntuDrivers: No module named 'UbuntuDrivers'
WARNING:root:could not open file '/etc/apt/sources.list'
Traceback (most recent call last):
  File "/usr/bin/software-properties-gtk", line 101, in <module>
    app = SoftwarePropertiesGtk(datadir=options.data_dir, options=options, file=file)
  File "/usr/lib/python3/dist-packages/softwareproperties/gtk/SoftwarePropertiesGtk.py", line 109, in __init__
    SoftwareProperties.__init__(self, options=options, datadir=datadir)
  File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 109, in __init__
    self.reload_sourceslist()
  File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 599, in reload_sourceslist
    self.distro.get_sources(self.sourceslist)
  File "/usr/lib/python3/dist-packages/aptsources/distro.py", line 93, in get_sources
    (self.id, self.codename))
aptsources.distro.NoDistroTemplateException: Error: could not find a distribution template for MX/Horizon
Re: Additional Drivers not working
#2 Postby Stevo » Sun Jan 07, 2018 6:24 pm
What do you mean "Additional Drivers?" We don't have any MX program called that.
This:
looks very odd. You know MX is not an Ubuntu derivative, correct?
#3 Postby timkb4cq » Sun Jan 07, 2018 7:50 pm
Software-properties-gtk is in the default debian repositories.
However the authors use only debian & ubuntu version identifiers to populate their lists. Since MX-16 doesn't lie & say it's debian jessie (or MX-17 is debian stretch) their code fails.
#4 Postby Stevo » Sun Jan 07, 2018 8:19 pm
Is "Additional Drivers" some sort of Debian GNOME tool, then? Maybe in gnome-software? I don't think you need that in MX--making this an "MX-Y" problem. :p
#5 Postby timkb4cq » Sun Jan 07, 2018 9:10 pm
BTW, installing software-properties-gtk in MX-15/16 messes up Synaptic by setting itself as the default executing binary for /etc/apt/sources.list
This causes Synaptic to report non-existent broken packages and causes its Settings -> Repositories menu entry to fail.
If you have installed software-properties-gtk , use
sudo dpkg --purge software-properties-gtk
to remove it. I haven't tried it, but I suspect software-properties-kde would be problematic as well.
davejones
#6 Postby davejones » Mon Jan 08, 2018 5:32 pm
[quote="Stevo"]What do you mean "Additional Drivers?" We don't have any MX program called that.
I don't know, but I'm pretty sure I didn't install that... Image
Maybe the
Nvidia Driver Installer
created it?
davejones
#7 Postby davejones » Mon Jan 08, 2018 5:46 pm
Alright, everyone, it seems I made the mistake of installing incompatible software on my MX-17 system. My bad! Already purged the package. Thanks!
Return to “MX Help”
Who is online
Users browsing this forum: No registered users and 3 guests
