-- Change in MX sources
-- antiX-17 release info here
mx17 personal remaster looses installed printers
imafraidknot
#1 Post by imafraidknot » Thu Jan 04, 2018 8:40 pm
Hej,
yesternight I mxed an mx17 live usb, started with persistence_all and proceeded like that:
sudo apt-get purge thunderbird libreoffice* bluetooth bluez
sudo apt-get autoremove
sudo apt-get install cups-pdf lm-sensors xsensors
sudo sensors-detect --auto
sudo apt-get update
sudo apt-get upgrade
then added add-ons to firefox and 4 printers to the system.
Then I remastered it personal.
Restarted, switched off persistence_all and there were no printers at all. Video is ok s.a. viewtopic.php?f=104&t=43685 .
This way worked for me from mx15. Did I do do something wrong or is it an issue?
cheerio bob
Re: mx17 personal remaster looses installed printers
#2 Post by dolphin_oracle » Fri Jan 05, 2018 8:51 am
I'll try to check into this today. Its possible there was some change to an excludes file. There were some changes in the live system between the 16 and 17 series.
lenovo ThinkPad T530 - MX-17
imafraidknot
#3 Post by imafraidknot » Tue Jan 09, 2018 11:04 pm
Any new ideas?
#4 Post by dolphin_oracle » Wed Jan 10, 2018 8:54 pm
could you post the output of
 cat /usr/local/share/excludes/*.list
also, what printer do you use?
FWIW, my HP setup survives a remaster.
imafraidknot
#5 Post by imafraidknot » Thu Jan 11, 2018 9:52 pm
dolphin_oracle wrote:could you post the output of
# general-remaster-exclude.list
# Additional files to be excluded when a general-purpose remaster
# is created.
etc/NetworkManager/system-connections/*
etc/X11/xorg.conf
etc/live/persist-config.conf
etc/udev/*-persistent-net.rules
etc/wicd/*.conf
etc/wicd/dhclient.conf.template
etc/wicd/manager-settings.conf
etc/wicd/wired-settings.conf
etc/wicd/wireless-settings.conf
var/lib/wicd/configurations/*
# live-remaster-exclude.list
# Files to be excluded when a live-remaster is created.
dev/*
dev/.[^.]*
etc/defaultdomain
etc/fstab.*
etc/ioctl.save
etc/issue
etc/mtab
etc/live/live-dir
etc/live/protect/remaster
etc/live/version/rootfs.ver
etc/mtab
etc/udev/rules.d/*-persistent-net.rules
home/*/.Xauthority
home/lost+found
live
lost+found
media/*
media/.[^.]*
mnt/*
root/.bash_history
root/.dbus
root/.gconf
root/.gnome2
run/*
run/.[^.]*
tmp/*
tmp/.[^.]*
swapfile
# usr/lib/python*/*.pyo
# usr/lib/python*/*/*.pyo
# usr/lib/python*/*/*/*.pyo
var/cache/apt-show-versions/*
var/cache/apt/*.bin
var/cache/apt/archives/*.deb
var/cache/debconf/*-old
var/cache/lightdm
var/cache/man/*
var/cache/samba/browse.dat
var/lib/apt/lists/*
var/lib/dbus/machine-id
var/lib/dhcp/*
var/lib/dpkg/*-old
var/lib/lightdm/.Xauthority
var/lib/lightdm/.cache
var/lib/nfs/rpc_pipefs/*
var/lib/sudo/*
var/lib/udisks/*
var/lib/urandom/*
var/log/!(samba)
var/log/samba/*
var/mail/*
var/spool/mail/*
var/tmp/*
var/tmp/.[^.]*
# rsync excludes file for mx-snapshot
# version 15.2.20
# Do NOT edit this entry block unless you know what you are doing
.bind-root
.config
.fehbg
lost+found
swapfile
tmp
dev/*
cdrom/*
grub/*
live/*
media/*
mnt/*
sys/*
proc/*
run/*
boot/grub/*
etc/adjtime
etc/bcm-ckd
etc/blkid.tab.old
etc/defaultdomain
etc/fstab.backup
etc/ioctl.save
etc/live/protect
etc/mailname
etc/mtab
etc/udev/rules.d/70-persistent-cd.rules
etc/udev/rules.d/70-persistent-net.rules
etc/resolv.conf
home/snapshot
root/.bash_history
root/.dbus
root/.gconf
root/.gnome2
var/cache/apt-xapian-index/index.*
var/cache/apt/*.bin
var/cache/apt/apt-file/*
var/cache/lightdm
var/lib/apt/lists/*
var/lib/dhcp/*
var/lib/dpkg/*-old
var/lib/sudo/*
var/lib/udisks/*
var/lib/urandom/*
var/log/!(samba|clamav)
var/log/clamav/*
var/log/samba/*
var/mail/*
var/spool/mail/*
var/tmp/*
# Entries below this can be edited by the user. If you have any large
# files or directories, you should exclude them from being copied
# by adding them to this list.
home/*/.cache/mozilla/firefox/*/cache2/*
home/*/.mozilla/firefox/*/Cache/*
home/*/.mozilla/seamonkey/*/Cache/*
home/*/.adobe
home/*/.macromedia
home/*/.thumbnails/large/*
home/*/.thumbnails/normal/*
home/*/.Trash*
home/*/.local/share/Trash/*
# home/*/.cache
home/*/.gvfs
home/*/.bash_history
home/*/.recently-used
home/*/.recently-used.xbel
home/*/.VirtualBox
home/*/VirtualBox VMs
home/*/.xsession-errors*
home/*/.xfce4-session.verbose-log*
# Examples:
# home/*/Desktop/*
# home/*/Downloads/*
# home/*/Music/*
# home/*/Pictures/*
# home/*/Videos/*
# Other possible exclusions
# usr/share/doc/*
# To exclude all hidden files and directories in your home, uncomment
# the next line. You will lose custom desktop configs if you do.
# home/*/.[a-z,A-Z,0-9]*
# This stops any video drivers from loading - safe option.
etc/X11/xorg.conf
etc/X11/xorg.conf.d/20-nvidia.conf
etc/X11/xorg.conf.d/20-intel.conf
etc/X11/xorg.conf.d/20-radeon.conf
# persist-save-exclude.list
# Files in this list will be excluded when a persist-save is done.
/etc/live/version/linuxfs.ver
# /etc/udev/rules.d/*-persistent-net.rules
/live
/lost+found
/tmp/*
/tmp/.[^.]*
/var/cache/apt/*.bin
/var/cache/apt/archives/*.deb
/var/cache/debconf/*-old
/var/cache/lightdm
/var/lib/apt/lists/*
/var/lib/dhcp/*
/var/lib/dpkg/*-old
/var/lib/lightdm/.Xauthority
/var/lib/lightdm/.cache
/var/lib/nfs/rpc_pipefs/*
# /var/lib/sudo/*
# /var/lib/udisks/*
# /var/lib/urandom/*
# /var/log/samba/*
/home/*/.cache/mozilla/*
/home/*/.macromedia/*
/home/*/.adobe/*
# static-root-delete.list
# The files listed here will be deleted at shutdown on live systems
# when static root persistence is enabled.
/tmp/*
/tmp/.[^.]*
/var/lib/dpkg/*-old
dolphin_oracle wrote:also, what printer do you use?
It's HP, generic-pdf and two other brands.
Return to “MX Help”
