  • Mepis support still here
  • MX-17.1 Final release info here
  • antiX-17 release info here
  • Read Forum Rules
Wifi Issue
JLS727
Wifi Issue
#1 Postby JLS727 » Thu Jan 04, 2018 12:21 pm
I have installed MX-17 on two Dell latitude laptops and they are running fine. However, every now and then they do not automatically connect to wifi on startup. I click the wifi symbol on the panel and then they connect. It's like they do not go out and look for wifi. This issue seems to be intermittent but if there is anything I could do to eliminate this I'd appreciate any thoughts. Thanks.
chrispop99
Re: Wifi Issue
#2 Postby chrispop99 » Thu Jan 04, 2018 12:55 pm
Right-click the network icon and select 'Edit Connections'
Select your connection, and click 'Edit'
Select 'General' tab, and click 'All users may connect to this network'.
Click 'Save, then 'Close'
Logout, then back in.
Please report whether or not this fixes your issue.
Test machines:
JLS727
Re: Wifi Issue
#3 Postby JLS727 » Fri Jan 05, 2018 12:30 am
I made the changes you suggested and so far it I have not seen the issue. Since the issue is intermittent I will need to see how it works over time to be sure, but so far so good. Thanks.
Jeff
chrispop99
Re: Wifi Issue
#4 Postby chrispop99 » Fri Jan 05, 2018 4:34 am
I'm reasonably confident it will fix the issue.
May I ask if you start your computer with auto login? In other words, it boots straight to the desktop, without you seeing the login screen.
Test machines:
JLS727
Re: Wifi Issue
#5 Postby JLS727 » Fri Jan 05, 2018 12:22 pm
No I do not use auto login. I have my systems set to always require the login screen with password needed to logon. Thanks.
Jeff
Re: Wifi Issue
#6 Postby dolphin_oracle » Fri Jan 05, 2018 1:13 pm
the situation is improved in mx17, but I think there is still a race condition in the network-manager startup that crops up for some people. I think richb had the issue during beta testing but it is very hard to duplicate.
We keep trying...living without systemd has its ups and downs.
another option is to use wicd, but you don't get all the plugins that network-manager supports.
lenovo ThinkPad T530 - MX-17
Re: Wifi Issue
#7 Postby richb » Fri Jan 05, 2018 1:24 pm
dolphin_oracle wrote:the situation is improved in mx17, but I think there is still a race condition in the network-manager startup that crops up for some people. I think richb had the issue during beta testing but it is very hard to duplicate.
Yes still do. At times wifi starts right up and other times not. More reliable on my laptop than desktop which I almost always need to manually start. For me it is a minor inconvenience.
Rich
SSD Production: MX-15- 64 - migrated to MX-16 RC1
HD Test: MX-16 RC1
AMD A8 7600 FM2+ CPU R7 Graphics, fglrx driver, 16 GIG Mem. Samsung EVO SSD 250 GB, 350 GB HD
chrispop99
Re: Wifi Issue
#8 Postby chrispop99 » Fri Jan 05, 2018 2:16 pm
@Richb:
Do you still have the problem with the 'all users...' setting checked?
Up until now, I've not had a failure to connect with that setting, and it seems to have worked for the OP.
Test machines:
Re: Wifi Issue
#9 Postby richb » Fri Jan 05, 2018 3:51 pm
chrispop99 wrote:@Richb:
Yes on the desktop. I will have to fire up the laptop to check, but think I have it checked.
Rich
HD Test: MX-16 RC1
Re: Wifi Issue
#10 Postby richb » Wed Jan 10, 2018 9:57 am
Finally got to this.
Laptop: Actually all users was unchecked. Checking it did bring up wifi on boot.
Desktop: All users checked and wifi does not connect unless enabled manually.
Rich
HD Test: MX-16 RC1
Return to “MX Help”
Who is online
Users browsing this forum: No registered users and 7 guests
