Cannot change keyboeard map
frapelli
Post by frapelli » Tue Dec 26, 2017 9:54 am
Installed MX 17 on an old IBM thinkpad.
Menu>settings>Keyboard>Map Model: generic; keyboard map:whatever (Italian winkey, It-Ibm, ecc). I have removed US keyboard.
Keyboard switcher on panel shows only US flag (which has been removed). Nothing happens when left-clicking, only information and exit with right-clicking.
What am I supposed to do to get italian keyboard).
Thanks
Re: Cannot change keyboeard map
Post by Jerry3904 » Tue Dec 26, 2017 10:15 am
First, the general approach is through the Users Manual, Section 3.7.2. If you followed that procedure (did you uncheck "Use system defaults"?) and see Italian in the keyboard layout in Settings > keyboard, you are good to go. That flag icon doesn't handle non-English very well, so unless you have multiple keyboards you can just quit it and either 1) uncheck it in session and Startup > Applications autostart, or just uninstall it.
frapelli
Post by frapelli » Tue Dec 26, 2017 10:44 am
Thanks Jerri3940.
Yes, I did follow procedure.
means:
but still US keyboard.
I tried all IT keyboards available.
Thanks
Post by Jerry3904 » Tue Dec 26, 2017 1:27 pm
You might need to log out and back in.
On a deeper level: could you check how the locale is set up:
$locale
. If that reads LANG=en_US.UTF-8 then you will need to reset that; check Users Manual Section 3.7.2
Eadwine Rose
Post by Eadwine Rose » Tue Dec 26, 2017 1:35 pm
I always do this after an install:
As su enter:
dpkg-reconfigure locales
I disable all non en_ and nl_ locales, and then choose en_us utf 8 as default
Might need to change that utf8 one for full effect?
MX-18_x64 20-12-2018 * 4.19.0-1-amd64 ext4 Xfce 4.12.3 * AMD Asus M4A785TD-V EVO AM3 * ASUS GF GT640-1GD5-L NVIDIA 390.87 * AMD Proc. Athl II X4 635, sAM3 * HDA ATI SB VT1708S An * 2x4Gb DDR3 1600 Kingston * 22" Samsung SyncMaster P2250 * HP Envy5030
frapelli
Post by frapelli » Tue Dec 26, 2017 2:50 pm
Thanks to all.
$ locale
LANG=it_IT.UTF-8
LANGUAGE=
LC_CTYPE="it_IT.UTF-8"
LC_NUMERIC="it_IT.UTF-8"
LC_TIME="it_IT.UTF-8"
LC_COLLATE="it_IT.UTF-8"
LC_MONETARY="it_IT.UTF-8"
LC_MESSAGES="it_IT.UTF-8"
LC_PAPER="it_IT.UTF-8"
LC_NAME="it_IT.UTF-8"
LC_ADDRESS="it_IT.UTF-8"
LC_TELEPHONE="it_IT.UTF-8"
LC_MEASUREMENT="it_IT.UTF-8"
LC_IDENTIFICATION="it_IT.UTF-8"
LC_ALL
With dpkg-reconfigure i tried it_IT@euro ISO-8859-15 and it_CH.UTF. Uninsalled all other locales and rebooted each time.
US layout keeps ruling my keybord. :mad:
Return to “MX Help”
