Where is ssd located and how to install mx linux
qlh09
Post by qlh09 » Tue Dec 26, 2017 3:30 am
Where is the ssd located inside the ideapad 110s computer?How do i install linux mx,any step by step guide?The only operating system i want on my computer is linux mx im going to be keeping the ssd just so you know but i want to see where it is located inside the computer
Eadwine Rose
Re: Where is ssd located and how to install mx linux
Post by Eadwine Rose » Tue Dec 26, 2017 4:17 am
I think you are better off googling the question ;)
https://www.youtube.com/watch?v=ciMu2zcNOSU
As the warning says in the video: check if this is your exact model.
And if you don't feel comfortable enough doing this: bring the thing to a shop and have them do it.
MX-18_x64 20-12-2018 * 4.19.0-1-amd64 ext4 Xfce 4.12.3 * AMD Asus M4A785TD-V EVO AM3 * ASUS GF GT640-1GD5-L NVIDIA 390.87 * AMD Proc. Athl II X4 635, sAM3 * HDA ATI SB VT1708S An * 2x4Gb DDR3 1600 Kingston * 22" Samsung SyncMaster P2250 * HP Envy5030
chrispop99
Post by chrispop99 » Tue Dec 26, 2017 4:52 am
Note that some versions of the Ideapad use an eMMC drive, some an SSD, and some have the capability to fit either! Verify what your machine has first!
I do a lot of laptop repair, and looking at the manual for the Ideapad 110s, I would rate replacing the SSD as medium difficulty. The base cover has to be removed by undoing 11 screws, then using a pry-tool to lift the cover away. The battery then needs to be removed. (Two screws.) The SSD can then be be removed by unscrewing a single screw.
If you have no previous experience of this type of work, I would advise against trying to do it yourself.
If you decide to go ahead, a PDF of the hardware maintenance manual is available from the Lenovo website.
Out of interest, what are you trying to achieve? Do you want the ability to put the machine back to an 'as purchased' state in the futures?
Test machines:
qlh09
Post by qlh09 » Tue Dec 26, 2017 5:07 am
But any pictures of where the ssd is located exactly on the back of the laptop(lenovo ideapad 110s) the laptop works fine i just want to take the ssd thing and put it back all by myslef
qlh09
Post by qlh09 » Tue Dec 26, 2017 5:09 am
And no i dont want to have the ability to put the machine back into its purchased state in terms of os i want to have my computer with mx linux installed onto the ssd and only have mx linux running
chrispop99
Post by chrispop99 » Tue Dec 26, 2017 5:27 am
qlh09 wrote:But any pictures of where the ssd is located exactly on the back of the laptop(lenovo ideapad 110s) the laptop works fine i just want to take the ssd thing and put it back all by myslef
Did you look on the Lenovo website for the hardware maintenance manual, as I suggested? There will be all the information you need in that PDF, including diagrams.
(Note my earlier remarks about the different HDD types used on this model!)
Test machines:
Post by asqwerth » Tue Dec 26, 2017 5:41 am
...no i dont want to have the ability to put the machine back into its purchased state in terms of os i want to have my computer with mx linux installed onto the ssd and only have mx linux running
Could you clarify whether you are asking:
1. where you can physically locate the SSD in the computer?
OR
2. where to "find" it in the installer while you are installing MX17?
chrispop99
Post by chrispop99 » Tue Dec 26, 2017 5:43 am
OR
so I hoped I had understood correctly.
Test machines:
qlh09
Post by qlh09 » Wed Dec 27, 2017 2:36 am
@asqwerth 1.Were can i physically locate the ssd in the computer
And any step by step guide on how to install mx linux?
Gordon Cooper
#10
Post by Gordon Cooper » Wed Dec 27, 2017 3:28 am
Firstly qlh09, welcome to the MX User Group. You will get plenty of help here but in this case, we need more information.
1. Have you an ISO copy of MX already on disk or a USb drive ready to install?
2. Does your computer already have an operating system that plan to replace with MX ?
Installation is fairly easy with plenty of guide data to help you, but you'll need to decide on an installation starting point.
I am wondering why you need to know where SSD is ? It does not matter unless you are planning to replace it. All installation/removal of data is done with the SSD connected and computer power on.
Primary: Dell9010, MX-18, Win7, 120 SSD, WD 232GIB HD, 4GB RAM
Backup :Homebrew64 bit Intel duo core 2 GB RAM, 120 GB Kingston SSD, Seagate1TB.
MX-17.1 64bit. Also MX17, Kubuntu14.04 & Puppy 6.3.
Return to “MX Help”
