MX-15/16 Tutorial Restore grub in EFI or Legacy mode
Topics relating to MX Docs and MX Videos
asinoro
#1 Post by asinoro »
Fast Fix MX Grub From MX
If you want to have the MX Grub, then from MX for Legacy Mode:
Boot repair from MX Tools,
Or open the terminal:
sudo su
Then:
grub-install /dev/sda ; update-grub
For Uefi Mode
Find first your Uefi partition to mount.
sudo su
parted -l
Where sdaX your EFI partition and run the command.
mount /dev/sdaX /boot/efi ; grub-install /dev/sda ; update-grub
If for some reasons it doesn’t work follow steps 1.7 to 1.10. for Uefi or Legacy.
Method Reinstall broken Grub
Reinstall broken Grub from Live Medium, DVD, USB
When you run the MX Live Medium, DVD, USB, open the terminal.
Step1
1.1. Run the command,
sudo su
1.2. Then the command, to see which partition has your OS.
lsblk -f
1.3. After the command, where X is your OS partition.
mount /dev/sdaX /mnt
1.4. Now you have to mount, bind and chroot mnt, with the follow command,
mount --bind /dev /mnt/dev && mount --bind /sys /mnt/sys && mount --bind /proc /mnt/proc && chroot /mnt
1.5. To verify that you are in the right partition run the command.
lsb_release -a
1.6. If for any reason something went wrong run exit command to execute again the procedure.
exit
Fix Grub on Uefi mode
1.7. Reinstall grub-efi it will ask you to remove grub-pc and mx-bootrepair you will say yes because both are for legacy mode and you don't need them.
apt-get install --reinstall grub-efi
1.8. Next is to find where is the EFI partition, run the command:
parted -l
It would look like:
2 1050MB 1322MB 273MB fat32 EFI system partition boot, hidden, esp
1.9. Replace the command sdaX with yours and run.
mount /dev/sdaX /boot/efi ; apt-get install --reinstall grub-efi-amd64 ; grub-install /dev/sda ; update-grub
Fix Grub on legacy mode
1.10. The most pc, laptop have the grub installed on sda where Windows are, and it is the correct way if you are dual boot with Windows. Enter the following command.
apt-get install --reinstall grub ; grub-install /dev/sda ; update-grub
If you run from live medium you can restart to find again you OS.
If you like to remember your grub the last operating system you have used then:
1.11.
sudo leafpad /etc/default/grub
Modify or add the missing commands:
GRUB_DEFAULT=saved
GRUB_SAVEDEFAULT=true
Save and Close the document and next:
sudo update-grub
Next time your PC or laptop will start with last OS you used.
Enjoy MX Linux.
If your case is solved, edit [Solved] to your initial post title to help other users.
Fix your Grub
Re: MX-15 Linux Tutorial Restore grub into EFI or Legacy mod
#2 Post by Jerry3904 »
That's great, thanks. I hope someone will run it through so we can verify it.
kmathern
#3 Post by kmathern »
I don't see a reason for downloading Super Grub2 Disk, I think you can pretty much do the same from the MX-15 LiveUSB/LiveDVD. That would eliminate steps 1 thru 3.
And in step 6.2 you can run the partition-info command to show which one is the EFI System Partition (ESP)
sudo partition-info all
asinoro
Re: MX-15/16 Tutorial Restore grub in EFI or Legacy mode
#4 Post by asinoro »
This tutorial has been updated and includes how to fix grub from live DVD, USB.
Fix your Grub
Return to “Documentation and videos”
