Just for kicks, you know.. should my cable or ethernet card fail for whatever reason or just.. well actually it was just for fun
Windows 7, which I thought would just work, didn't know what to do with the thing, the seller even gave me some software to install, no dice. I continued looking for a linux solution, was about to actually post for help, but then found this link here: http://ubuntuforums.org/showthread.php? ... st13380919
The two lines:
sudo wget https://github.com/porjo/mt7601/raw/master/src/mcu/bin/MT7601.bin -O /lib/firmware/mt7601u.bin
sudo modprobe -r mt7601u && sudo modprobe mt7601u
Here is what things are looking like now:
$ lsmod | grep 7601
mt7601u 102400 0
mac80211 630784 1 mt7601u
cfg80211 532480 2 mac80211,mt7601u
usbcore 233472 11 uas,snd_usb_audio,uvcvideo,usb_storage,ohci_hcd,ohci_pci,mt7601u,snd_usbmidi_lib,ehci_hcd,ehci_pci,usbhid
$ dmesg | grep 7601
[ 1.795118] usb 2-2: New USB device found, idVendor=148f, idProduct=7601
[ 12.938073] mt7601u 2-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
[ 12.976334] mt7601u 2-2:1.0: Warning: unsupported EEPROM version 0d
[ 12.976339] mt7601u 2-2:1.0: EEPROM ver:0d fae:00
[ 13.235363] usbcore: registered new interface driver mt7601u
[ 166.316842] Modules linked in: nvidia_modeset(PO) cpufreq_powersave cpufreq_userspace cpufreq_stats cpufreq_conservative nvram video msr uinput nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc fuse loop lp arc4 mt7601u mac80211 cfg80211 rfkill snd_usb_audio uvcvideo snd_usbmidi_lib snd_rawmidi videobuf2_vmalloc videobuf2_memops videobuf2_core snd_seq_device mt20xx tea5767 tda9887 tda8290 ppdev nvidia(PO) tuner tda7432 kvm_amd tvaudio msp3400 kvm bttv tea575x tveeprom videobuf_dma_sg edac_mce_amd snd_hda_codec_hdmi videobuf_core rc_core v4l2_common edac_core pcspkr evdev serio_raw videodev media i2c_algo_bit k10temp drm snd_bt87x snd_hda_codec_via snd_hda_codec_generic snd_hda_intel 8250_fintek sp5100_tco asus_atk0110 i2c_piix4 snd_hda_codec snd_hda_core snd_hwdep snd_pcm snd_timer
[ 166.317116] [<ffffffffa111ec16>] ? mt7601u_complete_tx+0x86/0x190 [mt7601u]
$ lsusb
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 148f:7601 Ralink Technology, Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 004: ID 046d:09a4 Logitech, Inc. QuickCam E 3500
Bus 001 Device 003: ID 059f:1018 LaCie, Ltd
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 002: ID 046d:c00e Logitech, Inc. M-BJ58/M-BJ69 Optical Wheel Mouse
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
I will post my earlier messages from the other (the actual running) system below when I boot into that and before performing those two lines so you can see the difference (if any) between mine and that poster's.
