[alpha Manual is here: http://www.mepiscommunity.org/manuals]
This section is designed to answer a new user's basic questions about how to use the OS once it is installed. In general, the object is to make succinct sections composed of
--a short introduction
--a bulleted list of the default application(s) for that category
--a couple of good links for each application to topics like home page, configuration, use, etc.
Below are some examples from the M11 Manual of general structure that should be used. As you can see, there is often text and links in Section 8 of the M11 Manual that you can take over.
The more people can give me an actual replacement sentence or paragraph the easier it will be to get this work done. If you want to send me images or longer texts, use this:
manual AT mxlinux DOT org
alpha Section 4
alpha Section 4
Re: alpha Section 4
Mepis is mentioned twice:
4.9 Games
Because of space limitation, MEPIS Linux
4.9.7 Windows®games
A number of Windows®games can be played in MEPIS Linux
Henry
4.9 Games
4.9.7 Windows®games
Henry
Re: alpha Section 4
4.7.2 - 'Thunar' not 'Dolphin'
