Alt-RightMouse no longer resizes?[SOLVED]
Richard
#1 Post by Richard »
Could have been something I did:
* Alt-RightMouse no longer resizes?
* Alt-LeftMouse doesn't move windows either?
(Corrected orientation, thanks Fehlix)
Prior to this, as I remember,
I stopped, or thought I did, Compton.
Started Xfce4 Compositing.
I did change the Thunar Custom Actions file --Could be, I'll check on that.
That's when I began to notice that Alt-RightMouse would not resize,
but instead just bring up Thunar right click menu.
Curious to know if anyone else has experienced this, or only me?
It's just sort of unusual.
Re: Alt-LeftMouse no longer resizes?
#2 Post by fehlix »
Richard wrote: Thu Nov 29, 2018 12:37 pm Could have been something I did:
* Alt-LeftMouse no longer resizes?
* Alt-RightMouse doesn't move windows either?
That's when I began to notice that Alt-LeftMouse would not resize,
The default for (default) right-handed settings are:
ALt - Left mouse to move a window
ALt - Right mouse to resize a window
Richard
#3 Post by Richard »
Ok, you are correct.
Since it isn't working for me
I guessed wrong. :)
Do these key comb. work for you?
#4 Post by fehlix »
Richard wrote: Thu Nov 29, 2018 1:42 pm Ok, you are correct.
I guessed wrong. :)
Yes, set/check in Windows Manager Tweak -> Accessibility : Key used to grab and move window: Alt - is default
Richard
Re: Alt-RightMouse no longer resizes?
#5 Post by Richard »
I must have touched the wrong button
yesterday while unsetting the external monitor.
That explains a lot other things.
Richard
#6 Post by Richard »
Found it.
Actually, it was even dumber. :(
I use the us_altgr international keyboard.
While looking around in MX Tweaks,
I thought it would be handy to have both Alt keys functional.
That's what changed the Alt-Right and Alt-Left key functionality. :bagoverhead:
BTW, there are quite a few new tweaks in MXT. Thanks.
Return to “MX Modified”
