View panel, help [resolved]
Lugue
#1 Post by Lugue »
:bagoverhead: Comrades, some of you know how to change that gray color so ugly?
Eadwine Rose
Re: View panel, help
#2 Post by Eadwine Rose »
Go into settings - window manager. You can change the style there.
#3 Post by asqwerth »
But you must have changed it in the first place so you know how. That is not the default icon or gtk theme.
You can also use mx-defaultlooks tool.
Lugue
#4 Post by Lugue »
Ah okay, thanks
Return to “MX Modified”
