Official blog post on Debian 9 and MX-16
Re: Official blog post on Debian 9 and MX-16
#11 Post by Jerry3904 »
Stevo wrote:Is our Jessie-built adobeflashplugin package still working in Stretch, for anyone that's upgraded?
Will check later.
#12 Post by anticapitalista »
Works on antiX alpha stretch version
#13 Post by Stevo »
Thanks! Though they are just running the precompiled binaries from Adobe, the packaging does some automatic shlibs stuff to create the dependencies for the packages, and I was hoping that what they pulled out for Jessie also worked for Stretch. Looks OK on that point--since Stretch doesn't have any working Flash installers at all.
#14 Post by Jerry3904 »
Works here on 16.1 changed over to Stretch. Adobe Flash Tester reports 26,0,0,131
Return to “MX Modified”
