printer settings
ratza555
printer settings
#1 Post by ratza555 »
Hi I have a canon ip4700 printer which i use but it dose not give me any choice of changing the print quality . Any ideas on how I change the quality or is it just not possible in mx-16 ?
Re: printer settings
#2 Post by Jerry3904 »
Here are some local resources to get you started:
1) search the Forum (under Quick links), there have been many discussions of Canon problems
2) check the Wiki: https://mxlinux.org/wiki/hardware/printer-drivers#Canon
Return to “MX Modified”
