Alt-SysRq REISUB (busier) works in updated MX-15 :-)
yop
#1 Post by yop »
Yeah! :popcorn:
_____________
re-edit: it works now ! :happy:
_____________
REISUB works as emergency shutdown in MX. However, some other SysReq features don't give output. Like on vt1,
Print a summary of available magic SysRq keys = SPACE
does not show a summary. Can it be done in Debian / MX ? https://en.wikipedia.org/wiki/Magic_SysRq_key
skidoo
Re: Alt-SysRq REISUB (busier) works
#2 Post by skidoo »
in a console (antiX16), Alt+SysRq+Space does display the available commands.
yop
#3 Post by yop »
skidoo wrote:in a console (antiX16), Alt+SysRq+Space does display the available commands.
I was not able to verify this here. shows nothing in xterm or vt1. installed & ran sysrq daemon even.
eemaestro
#4 Post by eemaestro »
Doesn't work in MEPIS Linux 12.0 Konsole either. Just turns the cursor from a black rectangle to a hollow black rectangle.
yop
Alt-SysRq REISUB (busier) works BY NOW !!
#5 Post by yop »
funnily enough ... my updated MX-15 now actually outputs Alt-SysRq text to the regular FD , that is, one can read it !
what a pretty little feature of MX the MAGNIFICENT distro again ! :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-)
skidoo
#6 Post by skidoo »
eemaestro wrote:Doesn't work in MEPIS Linux 12.0 Konsole either.
not "Konsole" nor other "terminal emulator app".
I was referring to to linux TTY console (reached from desktop session via Ctrl+Alt+F1 thru F6 keybinds).
yop
Alt-SysRq
#7 Post by yop »
after reboot it does no longer work, though... :snail:
yop
Alt-SysRq
#8 Post by yop »
yop wrote:after reboot it does no longer work, though... :snail:
you can use /proc/sysrq-trigger that'll work :fox:
like echo M > srq
eemaestro
Re: Alt-SysRq REISUB (busier) works in updated MX-15 :-)
#9 Post by eemaestro »
Okay, it worked in the MEPIS Linux 12 tty console. Gave four lines of text.
Return to “MX Modified”
