Issue with tooltips (YNAB 4 running in Wine)
Buddy-Matt
#1 Post by Buddy-Matt »
Hi all,
hope this is the right place to post this. I'm having an issue with tooltips. I've definitely seen it happen in YNAB 4 (Adobe AIR, running in Wine) - and sure I've seen it happen elsewhere (but can't remember where)
Anyway, all my tooltips look like this:
i.e. the words, letter, punctuation, everything replaced with crossed boxes :(
My gut says font issue, but I can't find anything online about this, so was hoping someone here would be able to point me in the right direction!
Cheers :)
Re: Issue with tooltips (YNAB 4 running in Wine)
#2 Post by Jerry3904 »
Can you please paste the output of this command:
inxi -F
Add to that any other information that would help us understand your system.
#3 Post by timkb4cq »
Do you have corefonts installed in Wine? I use winetricks to install them.
sudo apt-get install winetricks
winetricks corefonts
#4 Post by Stevo »
This Arch Linux user had the same issue and fixed it with the corefonts installation; probably where Tim saw it:
https://push.cx/2015/installing-you-nee ... arch-linux
Hopefully the installer is fixed by now.
#5 Post by Jerry3904 »
I'd still like to know if OP is actually running MX-15...
Pierre
#6 Post by Pierre »
you would need to know more about the OPs system,
but YNAB 4 does work in ./wine,
not sure about YNAB 3, would have to re-check that one.
- don't recall any issues that are Font related, though,
as it was always more an Adobe file issue, if anything.
Return to “MX Modified”
