Re: Audio problems (Solved)
MX-15 64-bit Trinity Desktop Environment fully updated with XFCE removed
I do not have audio when using VLC. An error message appears:" Audio output failed: The audio device "default" could not be used. Connection refused."
I have tried VLC>Tools>Preferences>Audio>Output Mode and tried Automatic, Pulse Audio, Alsa, etc. Nothing helps.
I do have audio when using my browser. When I go to Pulse Audio Volume control, a window opens and states: "Establishing connection to Pulse Audio. Please wait..." The connection never establishes. If I need to tweak the volume control on an online Youtube video, I cannot use PAVC.
However, when i reboot, PAVC is able to access Pulseaudio for a little while before crashing again. Sometimes, it connects to ALSA.
I've tried reinstall everything Pulse from synaptic.
'pulseaudio --check' from CL gives no output
'pulseaudio --start' from CL gives no output
'killall pulseaudio -9 && pulseaudio --start' from CL gives no output
If I logout login, it does no good. If I reboot, then pulse will behave for a few minutes.
Re: Audio problems
Sorry, Iforgot my hw info:
root@mx0:~# dmidecode
# dmidecode 2.12
SMBIOS 2.6 present.
60 structures occupying 2262 bytes.
Table at 0x0009F400.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: AMI
Version: P01-A0
Release Date: 08/13/2009
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 1024 kB
Characteristics:
ISA is supported
PCI is supported
PNP is supported
APM is supported
BIOS is upgradeable
BIOS shadowing is allowed
ESCD support is available
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
5.25"/1.2 MB floppy services are supporte
d (int 13h)
3.5"/720 kB floppy services are supported
(int 13h)
3.5"/2.88 MB floppy services are supporte
d (int 13h)
Print screen service is supported (int 5h
8042 keyboard services are supported (int
9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
CGA/mono video services are supported (in
t 10h)
ACPI is supported
USB legacy is supported
LS-120 boot is supported
ATAPI Zip drive boot is supported
BIOS boot specification is supported
Targeted content distribution is supporte
d
BIOS Revision: 8.15
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: eMachines
Product Name: ET1331G
Version:
Serial Number: PTNBA02001935104252700
UUID: 57112500-CDA4-0920-0830-030323000000
Wake-up Type: Power Switch
SKU Number: To Be Filled By O.E.M.
Family: eMachines Desktop
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Product Name: MCP61PM-GM
Version:
Serial Number:
Asset Tag: To Be Filled By O.E.M.
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: To Be Filled By O.E.M.
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
Handle 0x0003, DMI type 3, 21 bytes
Chassis Information
Type: Desktop
Lock: Not Present
Version:
Serial Number:
Asset Tag:
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00000000
Height: Unspecified
Number Of Power Cords: 1
Contained Elements: 0
Handle 0x0004, DMI type 4, 42 bytes
Processor Information
Socket Designation: CPU 1
Type: Central Processor
Family: Athlon II
Manufacturer: AMD
ID: 62 0F 10 00 FF FB 8B 17
Signature: Family 16, Model 6, Stepping 2
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction suppor
ted)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supp
orted)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
HTT (Multi-threading)
Version: AMD Athlon(tm) II X2 235e Processor
Voltage: 1.5 V
External Clock: 200 MHz
Max Speed: 2700 MHz
Current Speed: 2700 MHz
Status: Populated, Enabled
Upgrade: Other
L1 Cache Handle: 0x0005
L2 Cache Handle: 0x0006
L3 Cache Handle: 0x0007
Serial Number: To Be Filled By O.E.M.
Part Number: To Be Filled By O.E.M.
Core Count: 2
Core Enabled: 2
Characteristics:
64-bit capable
Handle 0x0005, DMI type 7, 19 bytes
Cache Information
Socket Designation: L1-Cache
Configuration: Enabled, Not Socketed, Level 1
Operational Mode: Varies With Memory Address
Installed Size: 256 kB
Maximum Size: 256 kB
Supported SRAM Types:
Pipeline Burst
Installed SRAM Type: Pipeline Burst
Speed: Unknown
Error Correction Type: Single-bit ECC
System Type: <OUT OF SPEC>
Associativity: 4-way Set-associative
Handle 0x0006, DMI type 7, 19 bytes
Cache Information
Socket Designation: L2-Cache
Configuration: Enabled, Not Socketed, Level 2
Installed Size: 2048 kB
Maximum Size: 2048 kB
Pipeline Burst
Speed: Unknown
Handle 0x0007, DMI type 7, 19 bytes
Cache Information
Socket Designation: L3-Cache
Configuration: Disabled, Not Socketed, Level 3
Operational Mode: Unknown
Installed Size: 0 kB
Maximum Size: 0 kB
Unknown
Installed SRAM Type: Unknown
Speed: Unknown
Error Correction Type: Unknown
System Type: Unknown
Associativity: Unknown
Handle 0x0008, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: J1A1
Internal Connector Type: None
External Reference Designator: PS2Mouse
External Connector Type: PS/2
Port Type: Mouse Port
Handle 0x0009, DMI type 8, 9 bytes
External Reference Designator: Keyboard
Port Type: Keyboard Port
Handle 0x000A, DMI type 8, 9 bytes
Internal Reference Designator: J2A2
External Reference Designator: USB1
External Connector Type: Access Bus (USB)
Port Type: USB
Handle 0x000B, DMI type 8, 9 bytes
External Reference Designator: USB2
Port Type: USB
Handle 0x000C, DMI type 8, 9 bytes
Internal Reference Designator: J4A1
External Reference Designator: LPT 1
External Connector Type: DB-25 male
Port Type: Parallel Port ECP/EPP
Handle 0x000D, DMI type 8, 9 bytes
Internal Reference Designator: J2A1
External Reference Designator: COM A
External Connector Type: DB-9 male
Port Type: Serial Port 16550A Compatible
Handle 0x000E, DMI type 8, 9 bytes
Internal Reference Designator: J6A1
External Reference Designator: Audio Mic In
External Connector Type: Mini Jack (headphones)
Port Type: Audio Port
Handle 0x000F, DMI type 8, 9 bytes
External Reference Designator: Audio Line In
Handle 0x0010, DMI type 8, 9 bytes
Internal Reference Designator: J6B1 - AUX IN
Internal Connector Type: On Board Sound Input Fro
m CD-ROM
External Reference Designator: Not Specified
External Connector Type: None
Handle 0x0011, DMI type 8, 9 bytes
Internal Reference Designator: J6B2 - CDIN
m CD-ROM
Handle 0x0012, DMI type 8, 9 bytes
Internal Reference Designator: J6J2 - PRI IDE
Internal Connector Type: On Board IDE
Port Type: Other
Handle 0x0013, DMI type 8, 9 bytes
Internal Reference Designator: J6J1 - SEC IDE
Port Type: Other
Handle 0x0014, DMI type 8, 9 bytes
Internal Reference Designator: J4J1 - FLOPPY
Internal Connector Type: On Board Floppy
Port Type: Other
Handle 0x0015, DMI type 8, 9 bytes
Internal Reference Designator: J9H1 - FRONT PNL
Internal Connector Type: 9 Pin Dual Inline (pin 1
0 cut)
Port Type: Other
Handle 0x0016, DMI type 8, 9 bytes
Internal Reference Designator: J1B1 - CHASSIS REA
R FAN
Internal Connector Type: Other
Port Type: Other
Handle 0x0017, DMI type 8, 9 bytes
Internal Reference Designator: J2F1 - CPU FAN
Port Type: Other
Handle 0x0018, DMI type 8, 9 bytes
Internal Reference Designator: J8B4 - FRONT FAN
Port Type: Other
Handle 0x0019, DMI type 8, 9 bytes
Internal Reference Designator: J9G2 - FNT USB
Port Type: Other
Handle 0x001A, DMI type 8, 9 bytes
Internal Reference Designator: J6C3 - FP AUD
Port Type: Other
Handle 0x001B, DMI type 8, 9 bytes
Internal Reference Designator: J9G1 - CONFIG
Port Type: Other
Handle 0x001C, DMI type 8, 9 bytes
Internal Reference Designator: J8C1 - SCSI LED
Port Type: Other
Handle 0x001D, DMI type 8, 9 bytes
Internal Reference Designator: J9J2 - INTRUDER
Port Type: Other
Handle 0x001E, DMI type 8, 9 bytes
Internal Reference Designator: J9G4 - ITP
Port Type: Other
Handle 0x001F, DMI type 8, 9 bytes
Internal Reference Designator: J2H1 - MAIN POWER
Port Type: Other
Handle 0x0020, DMI type 9, 17 bytes
System Slot Information
Designation: PCIE
Type: x16 PCI Express
Current Usage: Available
Length: Long
Characteristics:
3.3 V is provided
Opening is shared
PME signal is supported
Handle 0x0021, DMI type 9, 17 bytes
Designation: PCIE
Type: x1 PCI Express
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Handle 0x0022, DMI type 9, 17 bytes
Designation: PCIE
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Handle 0x0023, DMI type 9, 17 bytes
Designation: PCI2
Type: 32-bit PCI
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Handle 0x0024, DMI type 10, 6 bytes
On Board Device Information
Type: Video
Status: Enabled
Description: Nvidia Chipset
Handle 0x0025, DMI type 10, 6 bytes
Type: Ethernet
Status: Enabled
Handle 0x0026, DMI type 10, 6 bytes
Type: Sound
Status: Enabled
Description: Realtek HD Audio Codec ALC888S
Handle 0x0027, DMI type 10, 6 bytes
Type: SATA Controller
Status: Enabled
Handle 0x0028, DMI type 11, 5 bytes
OEM Strings
String 1: 01h
String 2: NVIDIA MCP61
Handle 0x0029, DMI type 13, 22 bytes
BIOS Language Information
Language Description Format: Long
Installable Languages: 1
en|US|iso8859-1
Currently Installed Language: en|US|iso8859-1
Handle 0x002A, DMI type 15, 35 bytes
System Event Log
Area Length: 4 bytes
Header Start Offset: 0x0000
Header Length: 2 bytes
Data Start Offset: 0x0002
Access Method: Indexed I/O, one 16-bit index port
, one 8-bit data port
Access Address: Index 0x046A, Data 0x046C
Status: Invalid, Not Full
Change Token: 0x00000000
Header Format: No Header
Supported Log Type Descriptors: 6
Descriptor 1: End of log
Data Format 1: OEM-specific
Descriptor 2: End of log
Data Format 2: OEM-specific
Descriptor 3: End of log
Data Format 3: OEM-specific
Descriptor 4: End of log
Data Format 4: OEM-specific
Descriptor 5: End of log
Data Format 5: OEM-specific
Descriptor 6: End of log
Data Format 6: OEM-specific
Handle 0x002B, DMI type 16, 15 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 8 GB
Error Information Handle: Not Provided
Number Of Devices: 4
Handle 0x002C, DMI type 19, 15 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x001BFFFFFFF
Range Size: 7 GB
Physical Array Handle: 0x002B
Partition Width: 1
Handle 0x002D, DMI type 17, 28 bytes
Memory Device
Total Width: 64 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM0
Bank Locator: BANK0
Type: DDR2
Type Detail: Synchronous
Speed: 400 MHz
Manufacturer: Manufacturer00
Serial Number: 00000000
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x002E, DMI type 20, 19 bytes
Memory Device Mapped Address
Ending Address: 0x0007FFFFFFF
Range Size: 2 GB
Physical Device Handle: 0x002D
Memory Array Mapped Address Handle: 0x002C
Partition Row Position: 1
Handle 0x002F, DMI type 17, 28 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM1
Bank Locator: BANK1
Type: DDR2
Speed: 400 MHz
Manufacturer: Manufacturer01
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x0030, DMI type 20, 19 bytes
Starting Address: 0x00080000000
Ending Address: 0x000FFFFFFFF
Range Size: 2 GB
Physical Device Handle: 0x002F
Handle 0x0031, DMI type 17, 28 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM2
Bank Locator: BANK2
Type: DDR2
Speed: 400 MHz
Manufacturer: Manufacturer02
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x0032, DMI type 20, 19 bytes
Starting Address: 0x00100000000
Ending Address: 0x0013FFFFFFF
Range Size: 1 GB
Physical Device Handle: 0x0031
Handle 0x0033, DMI type 17, 28 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM3
Bank Locator: BANK3
Type: DDR2
Speed: 400 MHz
Manufacturer: Manufacturer03
Asset Tag:
Part Number:
Rank: Unknown
Handle 0x0034, DMI type 20, 19 bytes
Starting Address: 0x00140000000
Ending Address: 0x0017FFFFFFF
Range Size: 1 GB
Physical Device Handle: 0x0033
Handle 0x0035, DMI type 24, 5 bytes
Hardware Security
Power-On Password Status: Disabled
Keyboard Password Status: Not Implemented
Administrator Password Status: Disabled
Front Panel Reset Status: Not Implemented
Handle 0x0036, DMI type 32, 20 bytes
System Boot Information
Status: No errors detected
Handle 0x0037, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Nvidia Chipset
Type: Video
Status: Enabled
Type Instance: 0
Handle 0x0038, DMI type 41, 11 bytes
Onboard Device
Type: Ethernet
Status: Enabled
Type Instance: 0
Handle 0x0039, DMI type 41, 11 bytes
Onboard Device
Reference Designation: Realtek HD Audio Codec AL C888S
Type: Sound
Status: Enabled
Type Instance: 0
Handle 0x003A, DMI type 41, 11 bytes
Onboard Device
Status: Enabled
Type Instance: 0
Handle 0x003B, DMI type 127, 4 bytes
End Of Table
root@mx0:~#
Re: Audio problems
Hi
Firstly I am not sure why you removed pulseadio and then whether you installed it correctly. So if you don't mind let me suggest a few things to you and then you decide if its worth trying.
PA=pulseaudio
step 1 clean up and correctly remove PA
Note the asterix at end of command. It will remove some sound stuff but it won't remove ALSA. And we can then do some further checks.
step 1b May not apply....remove any .config/pulse from your home dir....as a local user
step 2 full reboot and post the output of ...as a local user
and take a screenshot of
thats a zero not an O for orange as alsa counts cards/devices from zero.
Leave open terminal at mixer levels for step 3 resuls
step 3 go in web browser to your fav site and make sure you have sound if not unmute mixer level with
m key to mute or unmute
and use page up or down to quickly raise volumes or use up/down arrows to adjust
use left/right arrows to get to next control
step 5
to attempt to stop sound from stopping even tho we no longer have PA try this
right arrow to that pink setting and down arrow to choose disabled
step 6
Now press ESCape key to exit alsamixer assuming you can hear sound at correct volumes then we save that setting for alsa
step 7
go into vlc .....tools -> preferences -> audio -> pulldown audio output (You seem to know this area well) and choose alsa
don't forget to click on save.
Comment 1 by deleting PA you won't be able to use mx-system-sounds ....and I am not sure if want them or not
Comment 2 Once we have sound working with alsa only....with no interference from PA you can then try to regain PA with this command
which will re-install PA and some other bits.
PA=pulseaudio
sudo apt-get remove --purge pulseaudio*
rm -rf .config/pulse
inxi -Axxx
alsamixer -c0
step 5
step 6
sudo alsactl store
sudo apt-get install mx-event-sounds
Re: Audio problems
Thank you aus9 for trying to help. Unfortunately, i have now lost all sound.
I followed you instruction except for the last part about reinstalling PA.
I have all the outputs to max and nothing is muted. I have lost sound with my browser in YouTube.
I also tried Step 7. But, i still have no sound in VLC.
Edit: Automute is disabled.
I'm having difficulty uploading an image of alsamixer as you requested. When I try, I get an error message. I tried using GIMP to convert the Ksnapshot png to a jpeg. It still won't upload.$ inxi -Axxx
Audio: Card NVIDIA MCP61 High Definition Audio
driver: snd_hda_intel bus-ID: 00:05.0 chip-ID: 10de:03f0
Sound: ALSA v: k4.2.0-0.bpo.1-amd64
Re: Audio problems
I had my browser in firejail. That's why i couldn't upload. This is the image.
http://forum.mepiscommunity.org/downloa ... ew&id=8769
Re: Audio problems
Just to make sure this isn't a hw issue, I rebooted with a LiveDVD. I had audio when using the LiveDVD.
Re: Audio problems
Hi
good you have sound with live dvd.
It would be handy for you to have a screenshot of a working sound alsamixer as well don't you think?
but you will have pulseaudio as a front end. So I assume you did a MX tools -> setup -> select sound ? or what did you do? was sound working out of the box or did you need to unmute etc somethng in PA volume control?
2) Unfortunately I want a full screen shot.
Open terminal and maximise it pls.
MX menu -> all -> screenshot > select active window and choose Imgur which will give you forum copy strings.
3) If we know you have no interference from any asound config files, it should be safe for you to re-install PA but I will wait for your reply.
Leaping ahead, the other thing is you may have changed your phonon settings on hard drive. I don't use KDE and phonon but this guide might help?
https://userbase.kde.org/Phonon
4) but knowing you can get sound from a live MX means we will solve this!
Re: Audio problems
I did not do "apt-get install mx-event-sounds" when I posted.
I did do 'apt-get install mx-event-sounds". PA installed.
I went to Select Sound and a window appeared informing me that I only have one soundcard. I clicked OK.
PAVC still will not make the connection to device.
I went to Multimedia>Alsamixergui and fiddled around a bit. When I dragged the bars for Front Mic upward, I started to hear pink noise coming out of my speakers. Btw,. there is no microphone on this system.
http://forum.mepiscommunity.org/downloa ... ew&id=8772
I now have sound when browsing to YouTube. Btu, I still do not have sound from VLC. I tried setting VLC to use ALSA, Pulse< Automatic. "Connection refused."
As for the other screenshot, it did capture the whole screen.
Thanks,
-Joe
Thanks,
-Joe
Re: Audio problems
i did "alsamixer -c0" again. When I upped the bars fro Rear Mic, I again heard pink noise.
http://forum.mepiscommunity.org/downloa ... ew&id=8773
Again, this system has no microphones.
Re: Audio problems
Ok well thats a start.
Lets confirm something as you now have PA back on your system. If PA is correctly installed you should not see your sound card mixer stuff but a card called pulseaudio
No need for screenshot I trust you!...Just confirm it by note we drop the card number stuff.
2) now that we have PA and alsa ....and lets not forget you have phonon as well, strictly speaking if you see the card called pulseaudio you should only need to try automatic or pulseaudio in vlc.
2b) but even tho you posted your original hw info can you now redo it in case we have a gremlin please with either phonon or PA.
just show and report if inxi -Axxx is still the same, only post if it differs please
3) now the SDPDIF setting in this image
see how its turned on? go back to the pulseaudio volume control last tab called config and
if you see in any pulldown hdmi....probably top pulldown.....select off
and in any pulldown (for the moment no surround sound) for the analog ....select analog stereo output....not the duplux one
3b) retest sound in browser without a reboot as PA is supposed to make changes on the fly pls
3c) retest sound in vlc using either automatic with a save or pulseaudio with a save pls
good luck and leaping ahead.....if 3b is good but 3c is bad.....go back to alsamixer....and mute spdif and retest without exitting alsamixer and the unmute and retest and report.
spdif and hdmi....often are cousins and some cards need to be tricked for PA to play fair.
alsamixer
just show
cat /proc/asound/cards
