cpufrequtils is installed and is the latest version. If I type cpufreq-info I get:
This happens with both the default kernel (shows in GRUB as i686) and the alternate i586 available in the advanced options menu. The computer is a Dell Inspiron 700 with a single-core Pentium M cpu. cpufreq worked fine in the previous linux I had installed on this machine. Its "full" speed is 2.0 GHz, with a slower 1.0 GHz the rate at which it spent most of its time. Under MX it's been pegged at 2 GHz all the time.$ cpufreq-info
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to cpufreq@vger.kernel.org, please.
analyzing CPU 0:
no or unknown cpufreq driver is active on this CPU
maximum transition latency: 0.00 ms.
What would I try to fix this?
$ uname -a
Linux InspironMX1 3.16.0-4-586 #1 Debian 3.16.7-ckt25-1 (2016-03-06) i686 GNU/Linux
