Darker forum request - Solved
Coastie
#1 Post by Coastie »
Could a darker forum look like https://www.phpbb.com/customise/db/style/pbtech/ Image
or a gray https://userstyles.org/styles/browse/mxlinux be offered to be easier on the eyes?
MX-21.1 XFCE
ASUS M32
CPU: Quad core AMD A10-6700
HDD: 1 TB
RAM: 12 GB
Graphics: Integrated Radeon HD Graphics
Left Mac OS X for Linux in January 2014
Re: Darker forum request
#2 Post by richb »
It could along with several other scheme preferences. But it has not been a priority to make them available as other projects take precedence.
Paul..
#3 Post by Paul.. »
Very good idea, subject to prioritization against dev resources...
Samsung 860 500GB SSDs (2)
#4 Post by richb »
Yes. This came up before and was put on a to do list. However it is low on the priority list at the moment. Also it is not as easy as it sounds as we have several extensions that may not work with alternate themes. So quite a bit of work is involved to check everything out.
Coastie
#5 Post by Coastie »
Thanks, guys. I understand. I can use Firefox extensions until you can get to it. I would mark this as solved but don't understand the post icons.
MX-21.1 XFCE
ASUS M32
HDD: 1 TB
RAM: 12 GB
#6 Post by Jerry3904 »
You just go back to your first post, click the pencil to edit it, and add
[Solved]
to the Subject line.
Return to “Site Help”
